BanginOnABudget Posted April 6, 2011 Report Posted April 6, 2011 http://www.amazon.com/AUDIOPIPE-APSM-1300-2000W-Audio-Amplifier/dp/B004KA81AW came across this a few mins ago, was wondering if you guys thought it was actually 1 ohm stable??? if not, its still not a bad amp for the money. im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire. Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block.... 1990 Jeep Cherokee 2 Dr. Big-3 in 0g on Stock Alt. Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos. Pioneer 6000ub Reciever NO amps at the moment. SA-15 on 1kw coming soon. MSG Me for a free enclosure design!! Flared port kits coming soon!!
BanginOnABudget Posted April 6, 2011 Author Report Posted April 6, 2011 WOW. i just did some reading on floridaspl, and apparently these little beasts ARE 1 ohm stable! 1000wrms @ 1 ohm for $100!? FUCK YEAH! lol. dem guts. im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire. Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block.... 1990 Jeep Cherokee 2 Dr. Big-3 in 0g on Stock Alt. Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos. Pioneer 6000ub Reciever NO amps at the moment. SA-15 on 1kw coming soon. MSG Me for a free enclosure design!! Flared port kits coming soon!!
DannyV18 Posted April 6, 2011 Report Posted April 6, 2011 If you wire to 1 ohm nominal, you will seldom see an actual impedance very near 1 ohm, so I'd say it would be fine for 1 ohm if they say so. If it doesn't happen to work for some reason, contact them about it. Audiopipe is cheap as fuck. If i were on a strict budget i would probably run their amps.
BanginOnABudget Posted April 6, 2011 Author Report Posted April 6, 2011 If you wire to 1 ohm nominal, you will seldom see an actual impedance very near 1 ohm, so I'd say it would be fine for 1 ohm if they say so. If it doesn't happen to work for some reason, contact them about it. Audiopipe is cheap as fuck. If i were on a strict budget i would probably run their amps. well its either this amp or a rockford prime p500-1, which would you go for? in the long term i can get more power, but i wouldnt have that rockford reliability. im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire. Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block.... 1990 Jeep Cherokee 2 Dr. Big-3 in 0g on Stock Alt. Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos. Pioneer 6000ub Reciever NO amps at the moment. SA-15 on 1kw coming soon. MSG Me for a free enclosure design!! Flared port kits coming soon!!
DannyV18 Posted April 6, 2011 Report Posted April 6, 2011 Not sure about those "mini" line of amps by AP, but these line of amps have a good reputation as far as reliability and power output go. The rockford is more expensive and puts out less power, so i don't see why pay more for less power.
Sammitch0 Posted April 6, 2011 Report Posted April 6, 2011 Agreed go with Audiopipe I run a 1500D and it does rated @ 14.4 no problem 1 ohm stable all day. ONly thing is I've never seen the minis in action so I'd spend the extra $40 and get the regular version chances are the mini is over-rated and you won't see close to 1kwrms Grand Cherokee Team Backwoods Bumpers DC 15" Level 3's /w 4 Coils Pioneer deh4200ub Pioneer 3-ways Pioneer Tweeters Pioneer GM-D9500F Audiopipe 1500.1D @ 14.4v Clarion Equalizer Knuconeptz Kollosus 0ga Knuconpetz Kollosus 4ga Coming Soon: 270xp / xs1200
BlitZ Posted April 6, 2011 Report Posted April 6, 2011 they are 1ohm stable. and thats my pic... old set up Alpine IDA-X305S Memphis M-Class 4x6" Focal Access 6.5" Hifonics BRZ2100.1D 2x DC Audio Lvl 4 15's Big 3, DR44 Alt, Yellow Top http://www.youtube.com/user/SicNoma003
Decaf Posted April 6, 2011 Report Posted April 6, 2011 just got an ap10001d for 144shipped... little power house internals to compare
