i have recently acquired a Scosche 500K Micro Farad and i have done some research on how to install it but my friend keeps telling me i have to add it in like another battery... what i found online was that you hook the cable from bat up to + on cap and then run the + to the amp and then the - on the cap is grounded and the - on the amp is grounded... now on the other hand my friend said the same for + but you take the negative from the amp connect it to the - on cap and then ground it i need to what way would work the best and which way is right please.... btw i do know how to charge it so im looking for that... thank you very much for whatever assistance i can receive before i have to go to class..
The cap is just a waste of time, can put more strain on your system.
What amplifiers and such are you running?
Edited by azagtoth502
  • pa-pa-platypus
  • sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
If you have another batt its not a complete waiste.. Now im not sure on if it goes between the two batts or between the second batt and the amp. But if used correctly caps can help.. So why you guys sayin just to throw it away?
A .5 cap will do nothing 40 cap maybe but still it just adds to the load on the electrical system
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
This is prolly true. Im no cap wizz or anything.. I just know a good cap isnt a complete waist. I mean corect me if im wrong but dont they use glass absortion (or whatever its called) just like agm batts?
