12 guage for the subs and 16 for your mids and highs
NEW
2011 Chevrolet Silverado LTZ
2 XS Power D3400
Kicker HyperFlex 1/0
Soundstream Vir 7870bt
OLD
2010 Jeep Patriot
2 Murdered Out Black DC LVL 4 15s With XL Recones(with 1 extra spider pack a piece)
1 Crescendo BC 3500
1 MB Quart 60.4
1 Set RF T1 6x9s Up Front
1 XS Power D3400(Front)
1 XS Power D3400(Back)
2 runs of 1/0 Kicker Hyperflex
SoundStream Vir 7870bt
Fat Mat Rattle Trap Xtreme
[www.youtube.com/tntravelers33]
FEEDBACK
depends on your subs impedance.
500watts into half an ohm is over 30amps.
but 500watts into 8 ohms is less than 8 amps.
you are describing 2 different amps which has very little to do with what he was asking. A subs impedance has no effect on what size wire to choose, how much power and wire length are the only considerations you need.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
haha what are you trying to say
Thicker wires reduce resistance. The resistance of 16-gauge or heavier speaker connection cable has no detectable effect in runs of 50 feet (15 meters) or less in standard domestic loudspeaker connections for a typical 8 ohm speaker.[3] As speaker resistance drops, lower gauge (heavier) wire is needed to prevent degradation to damping factor—a measure of the amplifier's control over the position of the voice coil.
Insulation thickness or type also has no audible effect as long as the insulation is of good quality and does not chemically react with the wire itself (poor-quality insulation has occasionally been found to accelerate oxidation of the copper conductor, increasing resistance over time). High-power in-car audio systems using 2-ohm speaker circuits require thicker wire than 4 to 8-ohm home audio applications.
Most consumer applications use two conductor wire. Based on a guideline is that the resistance of the speaker wire not exceeding 5% of the rated impedance of the system the table below illustrates recommended lengths.
Maximum wire lengths for two conductor copper wire[3] Wire size 2 Ω load 4 Ω load 6 Ω load 8 Ω load
22 AWG (0.326 mm2) 3 ft (0.9 m) 6 ft (1.8 m) 9 ft (2.7 m) 12 ft (3.6 m)
20 AWG (0.518 mm2) 5 ft (1.5 m) 10 ft (3 m) 15 ft (4.5 m) 20 ft (6 m)
18 AWG (0.823 mm2) 8 ft (2.4 m) 16 ft (4.9 m) 24 ft (7.3 m) 32 ft (9.7 m)
16 AWG (1.31 mm2) 12 ft (3.6 m) 24 ft (7.3 m) 36 ft (11 m) 48 ft (15 m)
14 AWG (2.08 mm2) 20 ft (6.1 m) 40 ft (12 m) 60 ft (18 m)* 80 ft (24 m)*
12 AWG (3.31 mm2) 30 ft (9.1 m) 60 ft (18 m)* 90 ft (27 m)* 120 ft (36 m)*
10 AWG (5.26 mm2) 50 ft (15 m) 100 ft (30 m)* 150 ft (46 m)* 200 ft (61 m)*
source
R.I.P!
(Nov-29-2009)
92 explorer
current build
I think you misunderstood what I was saying. I wasn't saying the subs impedance makes no difference, obviously an 8 ohm sub will get less power (on the same amp) than a 2 ohm sub and you can use a smaller wire. However, even a 1 ohm set up that runs 250 watts needs a smaller wire than a 2000 watt set up at 4 ohms.
Thats what I was saying.
F150:
Stock :(
Processor: DSR1
yes but a 500watt @ 1ohm setup will need the same gauge speaker cable as a 2000watt @ 4ohm setup.
"A subs impedance has no effect on what size wire to choose"
in fact, the impedance has just as much effect on the cable size as the power.
:orly3:
R.I.P!
(Nov-29-2009)
92 explorer
current build
I didn't realize we were supposed to ignore voltage when considering what wire to use.
F150:
Stock :(
Processor: DSR1
  • Who's Online   0 Members, 0 Anonymous, 904 Guests (See full list)
