Power is exponential. You need 10 times the juice to produce twice the volume. It's not out of the relm of possibility to run 2500 on a 250 watt sub. Clipping is surely more dangerous to a voice coil than excessive power. As long as your enclosure is not too small as to limit the excursion of your sub, and you don't run it past it's mechanical limits, any properly rated sub will run with much more than it's rated RMS. Running more power gives you more headroom and the clarity at higher SPL is greater.
RMS is more of a guideline, not a strict rule. That is, as long as you know what you're doing.
Thanks for chiming in. See like i said it is possible. Ive done it a lot before. I have blown plenty of speakers from overpowering them but i also didnt know how bad clipping was and had the magic smoke and smell of a coil going up in smoke. But hey it happens, what a better way to learn what to not do when your wallet loses some weight. lmao.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
Oh really? Would you like me to prove you wrong? I put my 250w sub to the wall socket for fun and its dead but i have a 150w sub left and ill hook that to my 2600w amp if you want and get a vid of it. Its possible. Hell tons of ppl use bigger amps that put out more power than their subs are made to handle so if you think that just because you have a amp that is putting out more power than the sub is made for that you are going to blow the speaker you are wrong.
go for it.
obviously you'll be clamping the output from the amp to show the sub is actually getting 2500watts though.
Hahaha you really want to challenge me bro? I have the scope and clamp meter for it all. I'll do it. Give me some time tho cuz i work too damn much and im not playing my system at night, the neighbors dont appreciate that too much. lmao.
Edit: And just think im going to use my dc audio amp that puts out 175w per channel at 4 ohms, and i only have door speakers that handle 100w rms so i guess im going to blow them. NOT.
Edited by kickass audio
yup, what sub will you be using?
what enclosure?
either the voice coil will be hitting the backplate, or the spider will just rip itself apart.
unless of course you're playing like 500hz, and then the coil will just melt anyway
what? you're talking about giving a sub 10 times its power, not giving full range drivers less than double their power.
what enclosure?
bitching back and forth about that is not helping me
I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
ill use my shitty elevation audio sub that only has one coil connected to it. Also it will be a shitty box that i got for free from a shop just to have some bass in my car when i had it. Its so tiny that its not even funny.
And op, sry bro. Ill stop this shit right here.
Honestly i really dont see how sending more power to your speakers will kill them, as long as you prevent frequencies that are not supposed to play on that specific type of speaker from playing you should be fine. But then again what do i know.
thats whats wrong with this site now people bitching with in a thread about none sence if u dont agree with someone someone posted dont blow up my thread fighting about it i want help not to read about i o can do this with a follow up of someone saying u cant.
Yea thats my bad. Ill at least say sorry about it. I really dont see how sending it more power will hurt. I have somewhat the same thing. My old 5.25" speakers are in my room on my surround sound with an extra subwoofer on that same channel. The surround sound is supposed to put out 40w rms per 7 channels but idk what it is for sure since i never clamped it or anything yet. Point is, the tweeter is i believe 10-15w rms so it is getting more power than it should but im still running the crossover it came with so its not a problem.
All i really think you need to do is just get a good crossover on the tweeter so it has a steep slope to cutoff frequencies that the tweeter cannot support so you dont have a mid-range signal going to the tweeter. But thats all i have to say about it. It should be fine as long as your crossover is at a good setting.
My advice is to show both women equal attention. Though a 4 way with 3 chicks is most desirable. No one left watching if you can't perform two tasks at once. It's kind of like patting your head and rubbing your belly simultaneously.
Edited by pektel
fuck off with that its not funny.why is everyone on this site so quick do be a douche but when someone wants help its a differnt story
