DenBass Posted April 10, 2011 Report Posted April 10, 2011 hello. i have one problem. hope you can help me to solve it. car: vw passat sedan. rear seats: putted down. sub: kicker s15L5 box: ~100L ,2 ports. (nearly 1 meter each, dia 100mm) problem: low tones (under 37hz) plays really good only when I open sunroof.. Some people says that's because box too small, some because of roof flexin'.. what can you say? thanks. Kicker S15L5 (tuned to play 34-37Hz peaks)
Tarball Posted April 11, 2011 Report Posted April 11, 2011 hello. i have one problem. hope you can help me to solve it. car: vw passat sedan. rear seats: putted down. sub: kicker s15L5 box: ~100L ,2 ports. (nearly 1 meter each, dia 100mm) problem: low tones (under 37hz) plays really good only when I open sunroof.. Some people says that's because box too small, some because of roof flexin'.. what can you say? thanks. In short...it's able to breath with the roof open. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Bakerman Posted April 11, 2011 Report Posted April 11, 2011 Yeah, in previous systems, i've had boxes tuned low, and it only got "loud" when i opened the windows and/or sunroof. It just introduces a lot more air into the equation, allowing it to be louder...alot louder to the ear. You can make a bigger box that will be louder, but it will still get even louder when you open windows. If i'm wrong on this, someone please correct me.
canderton01 Posted April 11, 2011 Report Posted April 11, 2011 The cabin of your car becomes pressurized with all of your windows up, so when there is an opening like a sunroof or a window, it allows air movement which in turn makes it seem louder to the ear. 2002 Camry XLE 35% tints all around 17'' Enkei FD-05 rims Fi Q15 in 3.8cu ft box tuned to 32Hz Pioneer DEH-P7200HD AudioQue AQ1200d 4 Gauge Tsunami wiring/RCA's mids/highs - OEM JBL system AudioTechnix Deadner Big 3 upgrade My YouTube
blownengine Posted April 11, 2011 Report Posted April 11, 2011 Agree to all of the above. Subs sound louder when windows are open. 2003 Dodge Ram 1500 SLT (Yea its got a Hemi)Alpine CDA-105KnuKonceptz 0ga CCA Big 3 with Yellow Top 15" SoundQubed HDC3DC Audio 1.2K (Bass)Pioneer 6x9's (Front)Pioneer 6.5's (Rear)Kicker 3.5's (Dash)Sony amp on the highs. (Hey it was free)
DenBass Posted April 11, 2011 Author Report Posted April 11, 2011 thanks Kicker S15L5 (tuned to play 34-37Hz peaks)
