dubknight Posted April 10, 2011 Report Posted April 10, 2011 *ACCIDENTAL TITLE MISTAKE* - 10 10's not 8 10's, my bad 2 18" subs or 10 10" subs. Surface area on the 18's combined would be 2420 cm^2 Air Mass Volume based on Xmax(one direction) * Surface area = 7260 cm^3 Surface area on the 10's combined would be 3010 cm^2 Air Mass Volume based on Xmax(one direction) * Surface area = 5418 cm^3 Combined RMS handling for the 2 18's and 10 10's are identical. Box requirement for the 18's would be 16 cubes, the 10's would require 12.5 And details that may be asked for specifics: Amplifiers would be 2 AQ 2200's. Alts would be 500 amps at revs 2 D3100's in the back. TO BE CLEAR AS TO THE PURPOSE OF THIS THREAD Discuss the benefits or downsides to either two large subs or running many smaller subs. In the realm of SQ, SPL, and general logistics of pulling it off.
Supercharged DCs Posted April 10, 2011 Report Posted April 10, 2011 Two 18s will be easier to wire, ten 10s will have more cone area,better power distribution, and require less space than the two 18s. Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012.
Amerrricuh Posted April 10, 2011 Report Posted April 10, 2011 10 10s would be a huge wow factor. (UNDER CONSTRUCTION) Kenwood KIV-700 headunit 2 18" sundown Z.v3s 13.5^3 wall tuned @ 28hz SAZ-3500 DC power 270amp alt JL c2 650 AP600.4 XS 1200 under the hood XS 3100 in the trunk 1/0 gauge big 3 25^2ft audio technix ^^ c-fuzzy ur an idiot, my 15" soround is waay bigger cuz its a tall sorround, on top of that I HAVE A BIGGER MOTOR... oh yeah and fuck u suck my dick i got your hoes! anywhere they want to. They cant hear anyone telling them otherwise. just because its bigger doesnt make it any different. they just piss people off faster and farther away.
fox_racin4 Posted April 10, 2011 Report Posted April 10, 2011 10 10"s ftw ill be doin 12 10s once i sell my 18s 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
BeachJoshua Posted April 10, 2011 Report Posted April 10, 2011 If you're going for SPL you want to squeeze all the cone area you can into one space... | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars
Kobieblu Posted April 10, 2011 Report Posted April 10, 2011 I want 16 and I wanna fit them all in my civic RF love
dubknight Posted April 10, 2011 Author Report Posted April 10, 2011 Two 18s will be easier to wire, ten 10s will have more cone area,better power distribution, and require less space than the two 18s. Regarding multiple sub-woofers is there an issue with running many subs off a single amplifier in the sense that impedances aren't going to be the usual 1,2,4? 5 subs (DVC 4ohms) in parallel to the amp should give 1.6 Ohms if I did my math right. Do amplifiers care at all? I'm assuming not, but I want to cover my bases.
Kobieblu Posted April 10, 2011 Report Posted April 10, 2011 Do you only have 1 if so what kind RF love
Kobieblu Posted April 10, 2011 Report Posted April 10, 2011 All together clould get .8 close to one ohm stable? RF love
dubknight Posted April 10, 2011 Author Report Posted April 10, 2011 If you're going for SPL you want to squeeze all the cone area you can into one space... This is what I've been under the impression of, also why I put the statistic up top. Is there a way to mathematically calculate potential SPL or are there far too many variables when it comes to box design, sub true Xmax, etc..?
