How Much Will a Tunnel Affect Port Calculations?
for example
that area in the center is empty and essentially a port extension. would i calculate all the way up to the sub?
explain a bit if you understand the issue please
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
neither im just trying to do a standard ported box but this configuration is the only way i can fit that amount of subs
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
mustang trunk
max dimensions being 14h x 34w x 24d
8" subs (6 of them)
and 2k of power
and i have messaged Sani, I just like learning
Edited by IH8PunkRok
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
ok then do a 4th order with a 3:1 ratio
It's not a bandpass.
It's a ported blow through. The line on the front must be throwing you off. That line is marking the perimeter of the box, there's not piece of wood there.
Or, that's what I'm getting from this.
On 2/28/2013 at 2:52 PM, Chaise said:
"Now spread your butt cheeks so I can zap your asshole."
2008 Subaru Forester XT
  • Who's Online   1 Member, 0 Anonymous, 1206 Guests (See full list)
