Drilled a hole in my gas tank..
it is a metal gas tank
2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
Drop it out of the car, remove the fuel, insert a strong shop vac hose into the vent opening and leave it running to suck the fumes out for a few minutes and leave it on and drill smaller holes around the original hole, fiberglass chopp matt and resin it...and i'd call it good as new....but thats just ME...I'm in no way responsible for YOUR actions
Edit: Also if its a metal gas tank a neo magnet on the outside of the tank would more than likely prevent metal shavings in the fuel pump
Close but no cigar. :good:
You DO NOT need to get a new tank. To get the tank ready drain out and filter all the gas (into a large bucket then poor it into gas cans like it should be) to remove metal shavings, then use a neo magnet in the tank to get the rest of any shavings out. Blow the tank out with an air compressor while OUTSIDE to get rid of all fumes. Fiberglass over the hole just like BassJunkie said, or if it's metal, weld the hole closed. Then mask off all hoses and connections, and then spray the entire tank in bedliner to make sure it'll be strong and sealed. Reinstall and pour your gas back in, filtering it again. Good as new, worked great when i had to do it.
Edit: Forgot something.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
ok so what if i have a good layer of jb weld already on the hole and it doesnt work.. can i just put this shit ontop of it? im not able to actually remove the entire tank to sand it down and working in some tight quarters
Wouldnt do that. electric motor pumping out gas fumes. sounds like a bomb to me.
They make gastank patch kits. they work for awhile
I've seen a gas tank for a semi welded with fuel still in it using this method, also mythbusters proved that wrong. JS
thats for a semi (desil fuel) it burns slower and combusts under pressure. regular gas however is highly flammable i would not put a torch MIGwelder or arc welder any where near that hole.
if you think about it the tank would act as a giant cylinder and your welder would be the spark plug. the more vapor inside your tank will increase the potential for it to explode and create a larger explosion.
also note that having more fuel in your tank will reduce the amount of vapor in the tank.
i would replace it immediately.
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
How big is the hole? Can you screw a self tapper in with epoxy on the threads
good idea! :good:
i do agree with that. sounds like a good plan
