Drilled a hole in my gas tank..
So when doing my false floor i measured wrong i guess and drilled right into the top of my gas tank! :peepwall:
So tonight i dropped the tank and put some wire mesh ontop of the hole and then jb weld over that. do you guys think it will be strong enough to fix the problem?
2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
It may make it so it doesn't leak gasoline...personally I'd buy a new tank because vapors can still get out of it and into your trunk/cabin
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
:unsure:
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Measure twice cut once!!!! (Palm face)
Big 3 with Yellow Top
i used the entire two tubes that you have to mix together, and two layers of mesh just to make it a little stronger.
ya when i did it i was like shit, fml.
<_<<_< measure once cut twice. thats how i always done did it, i only made one vehicle so far sponatniously combust. :peepwall:
This page is crispy_chick3n approved.
© crispy_chick3n inc
To be safe I'd definitely put on a tank. Even a used tank would be better than the one with the hole.
Pioneer AVH-P4300DVD | Hertz 6.5 | Alpine Type R 6x9 | Custom 200A Alt | Knu Flek 1/0 Big 3 and all wiring | Eclipse EA3422 | AudioQue 2200d | DC XL 12 | Red Oak Box ~2.8 cubes @ 30 hz |
