sorry guys ive been real busy with school this couple of days. i should hopefully have some pics up tonight but heres a list of what we're using
SSR 4channel amp
8ga wiring kit
12v lawn mower battery
4 5.25" marine speakers
on/off switch from autozone
basically we followed what this guy did
http://www.keithsibson.com/2009/how-to-build-a-stereo-cooler/
let me know if there is something he missed out to tell that might be causing our problem
+ comes from source
ground is grounded (obviously)
acc goes to amp
(If I recall correctly... I might be wrong. If I am, someone correct me)
hell you dont even need to ground it really all the switch is doing is breaking the current and the ground for the 3 prong is usually for the lighted up switches
R.I.P!
(Nov-29-2009)
92 explorer
current build
+ comes from source
acc goes to amp
Well, yeah, I was accounting for the lighted switch.
If you just use + and acc, it will work, but without the ground, the light won't come on.
On 2/28/2013 at 2:52 PM, Chaise said:
"Now spread your butt cheeks so I can zap your asshole."
trouble shoot. take the remote wire, with the switch, out. hook up the amp. if the fuse blows again, your wires are backwards. if it doesnt, then you have the switch wired wrong.
show us the switch.
so you are sure you are hooking up power and ground correctly?? did you double/triple check? i see the terminals are screwed down, so when did the fuse blow? as soon as you made contact or somewhere in the process of putting the wire in a tightening it?
