how to wire 6 speakers at 4 ohms
i was wondering if it was possible to wire 6 speakers at 4 ohms. all the speakers are 4 ohm and 4 of them are 6 1/2s and 2 of them are 6x9s. i would like to wire three to each channel if possible
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
So they are going to a two channel amp and you want 3 on each channel.
Plus I dont know if its a good idea to run 6.5's and 6x9's on the same channel. And why at 4 ohms?
Big 3 with Yellow Top
4 ohms would draw the least amount of power. from the electrical system and what would be the problem with running 6.5s and 6x9s on the same channel
What amp? Speaker amps don't draw THAT much power. is your electrical really that maxed out?
Anyway you can wire the 6x9's on one channel at two ohms.
Then the other 4 6.5's to the other channel at one ohm or 4 ohms.
Thats if you separate the two speaker sizes.
Other than the fact that you just can't, don't.
why would it matter though if their both gonna be used for highs as long as my amp is set to high pass and their within the same amount of power
Not that I know of... if my high school physics memory is correct if you do 5 in parallel 1 in series you'll be looking at 5.25ohms
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
Its ok if you put the different size speakers on different channels.
for my senior project i have to make a product relating to audio since i chose modern audio as my topic. and since i dont have a car i was gonna make a new fourwheeler box with 4 6.5's and 2 6x9s and a storage area as my product. its a cheap dual amp that will do about 50 watts per channel rms at 4 ohms. my only issue is i only have 10 amps of fusing to run it on. right now it runs good on the 10 amps but im afraid if i run it at two ohms it would overload that fuse
  • Who's Online   0 Members, 0 Anonymous, 812 Guests (See full list)
