Dual 2 is dual 2 ohm voice coils. Dual 4 is dual 4 ohm voice coils. If you are more into researching this, look up ohms law and do a little bit of research on here.
Basically, can make the amp see different impedances(ohms) from your subwoofers. A single Dual 4 ohm sub can be wire to either 2 ohms or 8 ohms. A single Dual 2 ohm woofer can be 1 ohm or 4 ohms.
The more woofers you wire together, the more complicated it gets, especially when you are new to this whole thing. If your amp is only stable at 1 ohm, and you have too many subs of a certain Voice coild design and impedance, it can represent problems.
BassinBlazer
JL[RF][Kenwood][AQ]
I need a new amp! Sell me your amp!
Dude, run the positive of both subs to the positive bridges connection on the amp, then run the negatives from both subs to the negative bridged connection on the amp. Use the existing terminals and bitch slap the guy who set up your system the next time you see him because he is a tool.
BassinBlazer
JL[RF][Kenwood][AQ]
did rockford come out with a new line of subs? p1,2,3 to r1,2,3?
Edited by Jmoney2544
Car: 2002 Buick Regal
Wiring: Knu Kolossus 1/0 + JL 4 Gauge
Big 3: Stinger HPM 1/0
Alternator: Stock 135 Amp
Batterys: Optima RedTop (Hood) XS D3100 (Trunk)
HeadUnit: Pioneer DEH-4200UB
Subs: (2) AQ HDC3 12's
Sub Amp: AQ 2200D
Sub Box: 4.6 Cubes @ 36hz
Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's
Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25"
Speaker Amp: AQ4x90
Sound Dampener : 75 Ft Fatmat
  • Who's Online   1 Member, 0 Anonymous, 447 Guests (See full list)
