http://cgi.ebay.com/ebaymotors/1997-Dodge-Intrepid-V6-3-3L-3-5L-Alternator-160amps-_W0QQcmdZViewItemQQhashZitem2c5b9e699fQQitemZ190515669407QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
This is a 160 amp remanufacture alternato. Would this support my 18" FI BTL and AQ 3500???
If it will, would I need an extra battery? I have the big 3 done, and a stock alt, but Before I hook my system up I would like to know if this amp will support my system?
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
Audison Bit One processor
Jl-cl-rlc line driver
iPad in dash
Dual Irragi 320a alts
8 batcaps 4000's
Second Skin sound deadened
I would not trust that alternator to do 160A till 8000+ alternator RPM's... Go with DC Power Engineering or Mechman, they're more expensive but actually put out the rated amperage and at reasonable RPMs.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
kk, what is one of the good brands that would be a little bit cheape for me? the problem is im not shure howm uch longer I will have this car, so I didnt really want to spend the money on an alt if i might not have it for long, but who nows, maybe i will have it for a long time.
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
If i Did buy a DC alternator, would I need an extra battery?
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
or 2 batteries? or would the alt itself be just fine?
(4)DD 9918's
(2)DC 10k
8 6.5" focals
2 DD SS4 mid amps
iPad in dash
8 batcaps 4000's
i would buy an extra battery. with the alt. usually systems over 2000 watts need at least a big battery in the back and a decent one up front and you can get by on a stock alt. but if you buy a good battery in the back with that alt you should be alright. just do big 3 in 1/0 and youll be okay.
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
Guest DC Power Kyle
One good AGM battery and a good high output alternator and you'll be fine. Make sure to upgrade to 0ga wiring though.
