(6) Neo 8's *Rebuild Done* Vid up
just flipped it. much smaller intersection
i think after i run the router over it ill be good. i hope
i mean these things only have 12mm excursion but thats damn near an inch when you add both together
hmmm ima have to stumble into something good here
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
you could always add a spacer between the two
i cant really go any wider but i could pull about a half inch off both back walls
that would help
then id just fill in the gap with some scrap wood
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Instead of mounting the sub on the outside of the baffle, mount them on the inside with the top still off and make the top removable.
i wanted to do that but it wasnt possible. the back wall is in the way
check out what i did though. itll work nicely
chopped off 3/4" on both sides
left this gap which ill cover with a piece of mdf that ill use to unite the two boxes in the trunk
and i routed the back holes so the subs are flush. yes its ugly but it works
i think thats where im gonna stop tonight. im covered in saw dust. now that i know it works though everything else should be simple
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Going to be quiet. :facepalm:
You just had to do 6 8's didn't you lol
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
shoulda flipped one of the baffles so the subs are not firing into each other
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 5587 Guests (See full list)
