baaudio Posted April 23, 2011 Report Posted April 23, 2011 Okay so I've tried a couple things already. Put a ground from batt to alt. Replaced a factory ground for radio to a solid spot on the body. Now the noise does go with rpms just an FYI. When I unplug rcas from 4 channel noise stops. I don't seem to have any noise from subs, primarily comes thru tweeters. I haven't tried playing a seperate source to the 4 chan. Any other ideas guys? The noise started when I got in my car to go home from work. Worked perfectly fine before. Only thing I did was dump water out of my taillight. Team NWSPL baaudio Build Log 2001 GMC Sierra walkthrough 4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
zayres29 Posted April 23, 2011 Report Posted April 23, 2011 maybe one of your rcas has a short in it Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
baaudio Posted April 23, 2011 Author Report Posted April 23, 2011 maybe one of your rcas has a short in it that could be. i did notice that some of the grounding ends on the rca's were loose. (knukonceptz threads theres on) Team NWSPL baaudio Build Log 2001 GMC Sierra walkthrough 4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
bassinblazer Posted April 23, 2011 Report Posted April 23, 2011 It could also be high frequency noise that your subs isn't picking up because of the LPF on your amp. I would check that out also. If it is coming through your sub preamp too, then it is probably a ground loop somewhere in your wiring job. Also, bad spark plug wires can cause magnetic distortion as well, if they are shot, you may try replacing them as well. BassinBlazer JL[RF][Kenwood][AQ] I need a new amp! Sell me your amp!
zayres29 Posted April 23, 2011 Report Posted April 23, 2011 maybe one of your rcas has a short in it that could be. i did notice that some of the grounding ends on the rca's were loose. (knukonceptz threads theres on) ive heard mixed things about knu rcas try and see if thats the problem i use walmart rcas and never once had a problem with any noise Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
Krazykid122 Posted April 23, 2011 Report Posted April 23, 2011 i had the same problem once before in my old car, i think i just rewired everything and it worked, i use knukonceptz RCAs never had a problem< i have the karma ss series, when i got em all the ends were alittle lose but i just screw it on tighter, no biggie. wish i could be more help bro 02 Dodge Durango 1 Fi SP4 18" .v2 Sundown SCV3k @.5 Ohms XS D3100 up front Northstar SMS AGM 400 in the back All XS Power 0ga OFC 240a Apex h/o alternator Pioneer AVH-X2500BT HU Dual 0ga runs from the alt to battery Dual 0ga runs from battery to amp
baaudio Posted April 23, 2011 Author Report Posted April 23, 2011 Ya I have the Karma ss ones too. I figured it's the LPf that's stopping it. My sub rca's are kicker z series. But I'll try all that. I may try another hu too. Team NWSPL baaudio Build Log 2001 GMC Sierra walkthrough 4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
