CaptainzPlanetz Posted April 23, 2011 Report Posted April 23, 2011 Say you have a mid that has a built in crossover, then you put a external crossover before it??? I know it will eat up more power but does it change you crossover points??? I was just thinking of this out of the blue, so what happens? ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
zayres29 Posted April 23, 2011 Report Posted April 23, 2011 i would think it would act like a bandpass crossover but thats just a guess on my part Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
Forevrbumpn Posted April 23, 2011 Report Posted April 23, 2011 a bandpass is a hp/lp built in to one filter a cross over + crossover in series, its a different effect If you have a 6db hp and another 6db hp depending on crossover points you could accidentally create a 12db hp or a notch filter. Basically its not what you think it is I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
CaptainzPlanetz Posted April 23, 2011 Author Report Posted April 23, 2011 a bandpass is a hp/lp built in to one filter a cross over + crossover in series, its a different effect If you have a 6db hp and another 6db hp depending on crossover points you could accidentally create a 12db hp or a notch filter. Basically its not what you think it is I was reading into a bit of the stuff you said, and it makes some sense.....Anyone else got more insight?? Say you have to crossover's that both individually would give you a 70Hz HPF, if you where to have them series'd would it change that 70Hz HPF point? ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
mrd6 Posted April 24, 2011 Report Posted April 24, 2011 the crossover point won't change it will just change the slope. when in series you can basically think of the first crossover affecting the signal from the amp and the second crossover affecting that signal. So you have your original signal highpassed at 70hz, then that signal again highpassed at 70hz. So same crossover point just double the attenuation slope. If you change the crossover frequency of one of them then again you just have to imagine that the first attenuation occurs at one frequency and then the second at the other. Hope that helps! My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL
huh?do-what? Posted April 24, 2011 Report Posted April 24, 2011 you may tear a hole in the space time continuum. Be careful Marty. lol God damn its hot today. My balls are stuck to my leg.
NDMstang65 Posted April 24, 2011 Report Posted April 24, 2011 http://www.linkwitzlab.com/filters.htm If you want to read Authorized Ascendant Audio Dealer! Message me for information. If you can't explain it simply, you don't understand it well enough -Albert Einstein "I have a plausible excuse for not liking you. And you know why."
