Cut-out size help ?
Does anyone know what the actual cut-out diameter of a 6.5 speaker is ?? I am building my rear deck and i haven't got my 6.5's for the build yet but i am in the process of doing all the fab work and need to cut out the wooden rings the 6.5's will be housed in but everywhere i look it has the mounting info but not the actual size that i need to make the hole that the speaker will sit in . Thanks, i know this is a kinda general question but most 6.5's are the same size so . . .I have saw the pre-cut rings on Ebay but rather keep the price down and do them myself and they dont tell what the actual inside hole size is either !!
i just use the speaker or the trim ring itself when it gets here.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Size does vary a bit from speaker to speaker with 6.5s
So you you don't have the actual speakers? But you do know which speakers you will be using?
With a google search I'm sure you can find a site that is selling the speakers you want. They usually list....
A. outter diameter
B. Inner cutout diameter
C. Mounting depth
D. Sometimes the weight of the speaker
