4th order bandpass
jreese92
Sounds pretty interesting and something i would want to look into considering I'm only going to be running 1 SA-12 on 350 rms. They look really hard to build and I've never even built a sealed box, is there a calculator i could use to get dimensions for it?
Good luck with 350rms...i just ordered two and i was told they want at least 600rms. Cuz word is that they can handle more...
They can handle more but the noob telling you need more watts is stupid.
You dont need 600w.
350will be 'loud' too.
You dont have to overpower.
well if i ran the aq1200 and aq4x90 i would have no choice but to ugrade my electrical right? i really only want to use 1 battery (the one under the hood)
Pioneer 6300ub
Rockford Prime 6.5's
Pioneer 6x9's
Alpine MRP-M500
10" Alpine Type R
1.4 Cubic Foot Enclosure Tuned to 34 hz
Stinger 4 Gauge Wires
if you do the big 3 in 1/0 and upgrade the batt under the hood you should be good to go with no issues. :good:
edit: im sure you can get away with just doing the Big 3 as well. but only if you set your gains correctly and watch your voltage. but i would recomend a new battery under the hood. the xsd3400 is a great battery and its not too expensive.
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
what brand of wire would u guys recommend?
Pioneer 6300ub
Pioneer 6x9's
Alpine MRP-M500
10" Alpine Type R
knukonceptz.com has pretty good pricing.
try to buy 1/0 the KCA wire would be good enough for your set up. its 87$ for 50' of wire
Edit: they also have the Kollossus wire which is pretty cheap as well and its 100% copper
but if you want 100% copper you can get stinger, shok industries, or tsunami.
for stinger try darvex.com
for shok industries try mechman.com
and i cant think of any tsunami stuff off hand.
is 100% copper the best?
Pioneer 6300ub
Pioneer 6x9's
Alpine MRP-M500
10" Alpine Type R
yeah but its also way more expensive.
with your set up youll be fine with copper clad aluminum
seems like it would be worth dumping that extra dollar into the big 3 considering it would keep my car safe. But as for amp wires would i be okay running 4 gauge to the aq1200 and the aq4x90, or would i be experiencing major voltage drops and things like this?
Pioneer 6300ub
Pioneer 6x9's
Alpine MRP-M500
10" Alpine Type R
You dont need 600w.
true. u dont need 2x the rated power to get loud. 4th orders are very efficient. :good:
m_8e0e9deb0e2a020a7ff1bf0d3a6c3306.jpgth_140x100square.jpgth_140x100rev2animated.gifsoundigital.pngth_Banner_140x100.jpgn221468318568_2854.jpg
  • Who's Online   0 Members, 0 Anonymous, 1083 Guests (See full list)
