shorly after xmas i got all these goodies in the mail. As you can probably tell i didnt know exactly what i was doing so ya enough said. these are pictures of the OG install much have changed since then.
First off what i got
2 12" 2Ohm DVC Kicker L5s
Rockford Fosgate R1000-1D which came with a raptor 4 gauge kit
A ebay prefab box cause i don't trust myself making or wrapping one. Each chamber is 2.5 Cubic feet. no clue the tuning
Wire to my dirty battery terminals
Power under passenger side carpet
Remote, gain control and RCAs under drivers side carpet
Amp on back of box
box in back of truck
More pics of custom work to follow tomorrow before or after work.
Nice man, this is how I started in my navigator with two L5 12s and moved on to 4 L7 15s then on to 18s lol. Soon u will get use to it and want to upgrade lol, anymore pix?
BUILDLOG
http://www.stevemeadedesigns.com/board/ind...showtopic=61862
"98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!!
Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
Also there is a guy by the name of ridinclean on caraudioclassifieds.org selling custom door panels for your explorer if ur interested they're tooo sick!
BUILDLOG
nice start off bro, i remember my first system. in time you'll move up. see if you can screw that amp on the back seat, wouldn't wanna mess up the circuit board with the vibration would ya?
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
anymore pix?
coming up soon
i would be so down for those but since this is still in my parents name i dont want to do too much to it that i cant get back.
ya that would be bad though it seems out of everything in my truck the box vibrates the least. like all the seats feel like a toddler is behind you kicking them
So after a month or two of having the cheap 14 gauge wire to my subs i replaced it with solid copper stranded 10 gauge wire. In the process i broke one of the terminals. Cheapest 'metal' iv ever seen, pretty much aluminum with like crap iron inside. So i broke all the others off and drilled out the holes and replaced the terminals with solid nuts and bolts.
From the inside of the box
From the outside
More pics of changed to follow after work
Very nice.still tuned in!lol
99 expedition
Two 15 inch dc audio xls
Ported box tunned to 34 hrtz
Soundstream pcx.2000d(better amp soon)
0 gauge
big three(soon)
Yellow top,(more batts soon)
Next up I made some boxes to go on ether side of the subs to give it a custom look and keep the subs from moving. I made these out of scrap wood I had laying around my barn
Boxes all cut and put together
Sanded and primed
Put back together painted. I also painted the trim around the speakers
I also decided i wanted to put blue lights in each of the three cubbyholes of the boxes and in ether side of the port. I ran some thick speaker wire from the back dome across the headliner and down the side trim to then go in to a distribution box on the back of the subs. Here the five wires for the lights will connect.
wires with quick connects in dome opening
comes across the headliner to here then down the trim that is removed
comes out at the bottom and runs under my cargo mat then comes back up where it connects
wires soldered to dome light with quick connects
dome light reattached
DIY distribution box mounted
more to come after work tonight or after school tomorrow
This post will bring my build log up to date for now
I made a skateboard rack so I don't have to worry about my board flipping over and hitting my subs. Also adds something custom for who I am. The rack is made out of scrap wood like everything else then wrapped in felt with 3M spray adhesive.
Marking where rack will go for holes
Rack on box from back
Up next is finishing the side boxes. For this I made doors out of Lexan with aluminum bracing to make it more ridged. The doors are on bore-less glass hinges and have push release magnetic strike latches so there is no need for a handle and keeps a clean look.
Here is the left box with the doors installed
Left box with openings masked off
Left box wrapped in black felt before anything was cut
Right box masked off
Right box wrapped without anything cut
Right box all done with door in
I also cleaned up the port a bit. The box came with the port horribly sprayed and without the cut ends of the MDF sealed. I painted the port gloss black then sanded and filled all pores with wood filler. Once that dried I sanded again and panted a few more coats of gloss black on the port.
Sub openings(subs removed) masked off and first coat with wood fill
Port final coat done
SMD light installation coming up next
