Jmoney2544 Posted May 3, 2011 Report Posted May 3, 2011 Hey, they only make the Aq SDC2.5's in d4 so my final impedence is either .5 or 2 ohm. what amp will give me 2400-3000 watts in either .5 or 2 ohm for under 550? Car: 2002 Buick Regal Wiring: Knu Kolossus 1/0 + JL 4 Gauge Big 3: Stinger HPM 1/0 Alternator: Stock 135 Amp Batterys: Optima RedTop (Hood) XS D3100 (Trunk) HeadUnit: Pioneer DEH-4200UB Subs: (2) AQ HDC3 12's Sub Amp: AQ 2200D Sub Box: 4.6 Cubes @ 36hz Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25" Speaker Amp: AQ4x90 Sound Dampener : 75 Ft Fatmat
jmilch Posted May 3, 2011 Report Posted May 3, 2011 Hey, they only make the Aq SDC2.5's in d4 so my final impedence is either .5 or 2 ohm. what amp will give me 2400-3000 watts in either .5 or 2 ohm for under 550? AQ2200d It will run .5 ohm with good electrical daily. Pioneer AVH-P4300DVD | Hertz 6.5 | Alpine Type R 6x9 | Custom 200A Alt | Knu Flek 1/0 Big 3 and all wiring | Eclipse EA3422 | AudioQue 2200d | DC XL 12 | Red Oak Box ~2.8 cubes @ 30 hz |
Jmoney2544 Posted May 3, 2011 Author Report Posted May 3, 2011 Hey, they only make the Aq SDC2.5's in d4 so my final impedence is either .5 or 2 ohm. what amp will give me 2400-3000 watts in either .5 or 2 ohm for under 550? AQ2200d It will run .5 ohm with good electrical daily. i hear it gets hot as a mother and you cant turn it up even like 3/4 because it will go into protect Car: 2002 Buick Regal Wiring: Knu Kolossus 1/0 + JL 4 Gauge Big 3: Stinger HPM 1/0 Alternator: Stock 135 Amp Batterys: Optima RedTop (Hood) XS D3100 (Trunk) HeadUnit: Pioneer DEH-4200UB Subs: (2) AQ HDC3 12's Sub Amp: AQ 2200D Sub Box: 4.6 Cubes @ 36hz Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25" Speaker Amp: AQ4x90 Sound Dampener : 75 Ft Fatmat
TeamHT Posted May 3, 2011 Report Posted May 3, 2011 :facepalm: at who told you that. what do you mean turn it up? do you mean...the gain? there are many reasons why an amp would go into protect...and that is to protect the amplifier. in regards to your question what is your electrical like? you can guarantee youre going to want to upgrade from stock for the power youre looking for. Tell me...does this smell like chloroform to you?
Jmoney2544 Posted May 3, 2011 Author Report Posted May 3, 2011 :facepalm: what do you mean turn it up? do you mean...the gain? yes the gain remote. Car: 2002 Buick Regal Wiring: Knu Kolossus 1/0 + JL 4 Gauge Big 3: Stinger HPM 1/0 Alternator: Stock 135 Amp Batterys: Optima RedTop (Hood) XS D3100 (Trunk) HeadUnit: Pioneer DEH-4200UB Subs: (2) AQ HDC3 12's Sub Amp: AQ 2200D Sub Box: 4.6 Cubes @ 36hz Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25" Speaker Amp: AQ4x90 Sound Dampener : 75 Ft Fatmat
KMS Posted May 3, 2011 Report Posted May 3, 2011 You set the gain to match the RMS of the speakers/amp no? I have mine at around 46% turned over so I hope I'm not clipping. :\ Alpine PDX-V9 Morel Tempo 6 Alpine SBR-S8-4 Alpine CDE 149BT
TeamHT Posted May 3, 2011 Report Posted May 3, 2011 bass knob? you can not turn an amplifier up, it does not work that way. and gains must be set correctly to avoid clipping resulting in the malfunction of your equipment. if gains are set correctly, the bass knob can only be turned to match the max the gain is set to on the amp. i think someone who does not understand the equipment is giving you some bad information. you can take a look at crescendo, or possibly a kicker 2500.1 Tell me...does this smell like chloroform to you?
TeamHT Posted May 3, 2011 Report Posted May 3, 2011 You set the gain to match the RMS of the speakers/amp no? I have mine at around 46% turned over so I hope I'm not clipping. :\ what amp? and this is going to depend on a lot of things, also headunit. i would say turn down the gain until you can set them correctly. Tell me...does this smell like chloroform to you?
