What all should I get? and what is a P Chamfer, High QTS, and I heat ring. and wats the difference between the spiders if i got the spiders option?
Cooling:
P Chamfer:
High QTS:
Spider:
I Heat Ring:
18" Sundown Zv4 D2
JL 1000/1 V1
XS Power D3200
What amp are you running? Are you putting it in a sealed or ported box? The amount of power you're throwing at the woofer and the enclosure design will determine what options you'll need.
Cooling: The 2010 Q now features a solid pole piece that allows the addition of the Helicool cooling system that will allow an additional 200-500 watts of power handling depending upon install and scenario. Bottom line this option increases thermal power handling capacity over a “Stock” Q.
P Chamfer: This is a chamfer on the end of the pole, it helps to bring the air down around inside of the motor and helps cool the coil better. It also helps relieve the pressure underneath the dustcap. Please note if you select “Cooling” this option is included in the cooling package.
High QTS: This option is for users who intend on using the new Q series woofers in only a sealed enclosure.
Spider: This option adds an additional spider to the spider pack to help with mechanical power handling and keeping the moving assembly under control.
 I Heat Ring: This option is a machined aluminum ring in the gap that lowers the inductance of the voice coil which allows it to play up a little higher in the frequency range and have better overall transient response. Please note that you can NOT select low Qts and the I Heat Ring options together.
Edited by Maxim
wtf is lolcats?
I'd def get a fat hooker if i had to resort to that kinda thing. I feel like they'd be grateful and work harder. Also its more bang for my buck, more real estate for my dollar if you catch my drift. its like the Costco of streetwalkers.
I was hoping for 150 :(.
I was hoping she would let me put it in her butt
What amp are you running? AQ1200D at 1 ohm
Are you putting it in a sealed or ported box? 4CuFt ported box tuned to 30 Hz
Edited by HotRodHam
18" Sundown Zv4 D2
JL 1000/1 V1
XS Power D3200
so will 1 15" Fi Q handle a AQ1200d at 1 ohm? wat do u guys think
18" Sundown Zv4 D2
JL 1000/1 V1
XS Power D3200
i think it will handle the 1200 d no problemo, as long as you're not clipping.
as far as the options go, This should help you out quite a bit.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
My setup is really similar to what yours could be. I'm running a Q15 on an AQ1200 @ 1 ohm in a 3.8cu ft box tuned to 32hz. The only option I got on mine was the extra spider. And yes the Q will take on every bit of the AQ no problem. The newer Q's are beasts.
2002 Camry XLE
35% tints all around
17'' Enkei FD-05 rims
Fi Q15 in 3.8cu ft box tuned to 32Hz
Pioneer DEH-P7200HD
AudioQue AQ1200d
4 Gauge Tsunami wiring/RCA's
mids/highs - OEM JBL system
AudioTechnix Deadner
Big 3 upgrade
My YouTube
How does it hit? I was going to be getting the Q also once I get the money.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
It's not a BTL or an SMD, but the Q series is notorious for belting out the low lows and being musical, plus it can still get pretty damn loud. In short it is a damn good woofer and yes it does hit lol But if you're saving up for a Q, be sure to get a decent amp to match.
Edited by canderton01
2002 Camry XLE
Pioneer DEH-P7200HD
AudioQue AQ1200d
Big 3 upgrade
My YouTube
I was either getting RF t1000-bdCP or 1500 for it.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
The FI Q's are badass, but on a 30 day build time right now I believe. Worth that wait if your not in a big rush. just incase you didnt see the flashing bold red text on their website on the Q's.
