I'm going to be running the dc 2k amp and I have a stock amp and battery, will I need a new alt and battery or could I get away with it? Or should I do the big three and new battery? Or just do it all?
Depends on how much current your factory alt can produce. If all your running is a 2k, I'd say just get the biggest XS batt you can fit under your hood, big 3, and maybe a smaller secondary batt like a D975 in your trunk depending on your voltage. But if you have the funds to buy a new alt and plan on upgrading you equipment down the road, then go for it.
2002 Camry XLE
35% tints all around
17'' Enkei FD-05 rims
Fi Q15 in 3.8cu ft box tuned to 32Hz
Pioneer DEH-P7200HD
AudioQue AQ1200d
4 Gauge Tsunami wiring/RCA's
mids/highs - OEM JBL system
AudioTechnix Deadner
Big 3 upgrade
My YouTube
start off with a second battery but definitely do the big 3 also, your truck should be fine on that amp..
Stock 117A alt, XS D3400 under the hood, Big 3 in Ogauge. Voltage doesn't drop below 14v at full tilt, and around 13.7v at idle.
  • Who's Online   0 Members, 0 Anonymous, 1098 Guests (See full list)
