hello. their this seller on Craigs that is selling this amp to for $80 but i got to drive all the to him, about a 20 minute drive.. anyways... i want to know if these amps are any good? anyone ever owned these amps? how did they perform? i did some research on this amp and read nothing but good reviews. i just want to know and hear from you people :].
i got (2) 10 inch Alpine Type-Rs in a ported box, so you guys think it will be a good match up? ... also i have another seller in mind.. he is selling an Alpine MRD-M1005 amp for $100 (he might be flexible on price).. or should i go with this Alpine amp?
any input or suggestions will be appreciated :]. thank you for your time.
iDA-X200/Clarion EQS746
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Alpine & Polk Speakers
Stock electrical
bump?
well i gone ahead and bought the RF 800a2.. it has dual power and ground outputs.. anyone know how to set this up? i never had an amp that had this..
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Stock electrical
the 800a2 is a beastly amp got 2 with me over in okinawa. 8 0 bucks is a steal. heres the owners manual http://www.rockfordfosgate.com/scripts/rightnow.cfg/php.exe/enduser/fattach_get.php?p_sid=N_hfpSOj&p_tbl=9&p_id=340&p_created=1083781892
also its not a bad match up for the type r's but they can take alot more power aswell
Edited by bre2ts
you win some, you lose some
That is one of my favorite amps. I have abused it many times over the years. When I first got my Diamond Audio D3's, I ran them all on it @ 1ohm. It held up, definately ran a little warm, but it's only rated for 4ohm mono.
bump?
i hooked everything up. should i run another power wire from the amp? b/c right now i have just one wire connected, same as the ground. and what will be best way to wire my subs?... i got dual 4 ohm subs..
thanks people..
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Stock electrical
bump?
thanks people..
there are dual power and ground terminals so you must use both. easiest way would be to get a single run of 4 gauge and run it into a distribution block and split it into 2 8 gauge (iirc thats what the amp has) and wire as normal. you can do the same thing for ground or you can just do 2 8 gauge runs to the same ground spot on the frame.
bump?
thanks people..
thanks for the reply Kranny :]... im just running one power and one ground wire.. and it works fine .. but im pretty sure its just using half of amp's power..agree? you think it would be fine if i ran just 2 power wires into the amp and just one wire on the ground?
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Stock electrical
i wouldnt run it like that for long. think about it, there is a reason why RF put 2 sets of terminals on there. and no you must use matching sizes and numbers of power and ground wires.
On the inside of the amp, both the power terminals go to 1 big block. But running both sets will let more amperage through the wire. I got an 800.2 which came out a year after the 800a2. It runs hot but its been in like 5 cars with different sub setupsand still works good. By birthsheet said like 980 watts @ 4ohm mono
99 GMC Suburban
2 Death Penalty 21"
2 Crescendo BC2000
Boston GT-42 Amp
6 Selenium 6w4p
4 Crescendo tweets
Hi output cs144 alt
Audiocontrol Epic-160
Pioneer DVD head unit
I got 2 dual 4 ohm subs.. What will be the best way to wire these babies up?
RF T500-1bd
(2) 12" RF HX's
Kicker 350.4
Stock electrical
  • Who's Online   0 Members, 0 Anonymous, 1053 Guests (See full list)
