what kind were the black batts i know the one was kinetic
NEW
2011 Chevrolet Silverado LTZ
2 XS Power D3400
Kicker HyperFlex 1/0
Soundstream Vir 7870bt
OLD
2010 Jeep Patriot
2 Murdered Out Black DC LVL 4 15s With XL Recones(with 1 extra spider pack a piece)
1 Crescendo BC 3500
1 MB Quart 60.4
1 Set RF T1 6x9s Up Front
1 XS Power D3400(Front)
1 XS Power D3400(Back)
2 runs of 1/0 Kicker Hyperflex
SoundStream Vir 7870bt
Fat Mat Rattle Trap Xtreme
[www.youtube.com/tntravelers33]
FEEDBACK
what state or city is this guy in?
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
shurikens or whatever batts
Edited by BassJunkie
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
i understand your mad and everything but putting an addy up isent the smartest thing to do, not to mention theres some crazy fucking people out there, just sit outside his house till he gets home
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
Ok...update...I was trying to charge it earlier still, and when I touched the negative of the charger on a good batteries negative terminal the amperage on the charger would actually rise and start charging. So I started messing around with the kinetik and I rolled it on its side and it sounds like something inside is rolling around, and there is a small crack under the screw on terminals so I'm thinking maybe the negative side of the battery is disconnected and broken internally. After watching xs powers vids of an open kinetik I think its quite possible this has happened by the way it looked like some batts were designed. WILD IDEA..hear me out. Could I discharge the battery completely using a clamp light or some sort of battery discharging device and make it safe enough to open this case to repair the battery? Is there anyone who could repair the ground on this thing?
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
I wouldn't even bother. I'd chalk it up as a loss and try to get my money back. Lesson learned. NEVER buy used batteries!
x2, not worth it to open it up and run the risk of being zapped to shit, and the likely hood of actually being able to fix it, eh.
Look into some deka 9a31s if your on a budget, or xs power if you can afford it. :)
