Well i just made my new box the other day its for two HDC3 12s its tuned to 33 hz. Ok all my sides are flush on the box that is not my problem. The problem is that my seals on my box are breaking and im starting to get that wood slappin sound. I put 1 1/2" nails around it when i was glueing everthing together. What can i do to seal it back and stop this noise without taking my new box apart. Oo BTW AQ designed the box so nothing is wrong with the design the glue just didnt hold
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
What glue were you using? I've never had a problem with glue not holding.
It was liquid nails panel and foam this was the only stuff that said for mdf
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
Titebond II or Titebond III wood glue is what you should use. Also what type of nails did you use? They should be brad nails.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
They were wire nails they wernt big but they wernt tiny. I didnt know what kind to use this was my first box. Any ideas w/o taking it apart
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
If the seal keeps breaking, then it's time for a new box.
That was the title i havnt tried anything yet i only built it 2 days ago a new box.. I doubt it im gonna try some stuff before i make another
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
If you don't want to take it apart, you could pre-drill and use sheetrock screws, I guess. x2 on the Titebond, it's bond is stronger than the MDF.
I don't see that you even really have a choice,since it's probably not feasible to take it apart anyway. Most likely you'd damage the MDF removing the liquid nails.
2007 Pacifica
Well try fitting some glue inside the cracks, g some 1 5/8" coarse Drywall screws, silicon the all edges and hope for the best.
Well i guess ill go buy some sheetrock screws ang give it a shot
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
  • Who's Online   0 Members, 0 Anonymous, 824 Guests (See full list)
