Square port
SPLVan
well , a port 8"x8" x 30 gives you 37 htz , 7"x7" x 24 gives you 33 htz , this gives you an idea of what you goin for
but these ports are gonna be external and i dont want 30 or 24" of port coming out of my box..
1999 Dodge Caravan
[TrashMobile]
8ga Power/Ground
AudioPipe APSM-1300 (subs)
Scosche 550 (mids/highs)
Boss 735UA Headunit
(2)Hifonics HFi12D4
Still Under Major Construction..
ok do 4 3" ports x 7 , what are you trying to do
im trying to get 10 square inches of port per cube. so i think ill try and find a way to squeeze(2)5x5 6 inch long square ports.
1999 Dodge Caravan
[TrashMobile]
8ga Power/Ground
Boss 735UA Headunit
(2)Hifonics HFi12D4
at 6 inches your at 50 htz, what htz do you want to be at?
the dimension i originally posted were off. the right ones are 21H 27.5W 17.5D
im trying to get high 34hz
1999 Dodge Caravan
[TrashMobile]
8ga Power/Ground
Boss 735UA Headunit
(2)Hifonics HFi12D4
not going to happen .... a box you size would need a port 6x6x15 to be at 35 , and the port may be a little small 10x4x24 would give 40 square inches a little better , you may need to start over ... sorry for the bad news
are you saying two 5x5 wouldnt work?
1999 Dodge Caravan
[TrashMobile]
8ga Power/Ground
Boss 735UA Headunit
(2)Hifonics HFi12D4
it will work but wont be right , thats only 25 square inches , kinda small 50 square inches would be better , if you run 2 that size , the ports will be 32 inches long , one 5x5 will be 9 inches,so yes it will work , but it could be better ..
so should i do 6" aero ports?
1999 Dodge Caravan
[TrashMobile]
8ga Power/Ground
Boss 735UA Headunit
(2)Hifonics HFi12D4
  • Who's Online   2 Members, 0 Anonymous, 1075 Guests (See full list)
