Let me first start off that I have been using dynamat and hushman for the last 8 years, love the product and never thought twice about using anything else. Joined SMD this past October and started doing some research on some other alternatives, since there is quite a few to choose from now. Second skin naturally was a great choice. Compared to dynamat extreme, I would use the damplifier pro EVERYTIME. You couldn't give me dynamat after using damplifier pro. I used it on my doors and it is great, does the job like it should for my application. I have quite a bit of flex that I was trying to limit, the damplifier pro reduced it alot. So.....
I decided to do the floor of my sierra, did a layer or two or three or four, lost count, just used what I had left until it was gone. Then began to spray the spectrum over that. I honestly didn't think it could get any better, but every coat I added every hour, the better and better it seemed to get. Exactly what I was looking for. Great product guys and I am so glad I got 5 gallons of this stuff.
Question: I am going to spray this under my floor pan and frame, I plan on cleaning the surface with simple green/purple power first, then 5-6 coats like I did on the inside? Thanks
And Pics....
Damplifier Pro installed
First coat of Spectrum over the damplifier pro
6 coats later....
Even did the gas pedal arm cuz I liked the look of this stuff so much.
Floor is already feeling pretty solid, should be even better the more this stuff cures.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
I definitely like the spectrum.
DP is outta my rice range though.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
Nice job with the spectrum over the 0 gauge make it look stock...
Working on my 93' Ford Bronco rebuild:
I have:
pioneer AVH-P6500
Infinity Reference 6032SI fronts
Infinity Reference 6832CF Rears
Crescendo CZ 6.5 kicks
Crescendo 1100.4
(2) DC Audio LvL 4 M2's
(1) Juicebox Blackcherry
Piece together amps & wiring
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
Sky High Car Audio Wire
Rockford Fosgate 360.2 or .3
My Build
http://www.stevemeadedesigns.com/board/topic/97426-93-ford-bronco-rebuild-full-system-body-paint/
Awesome work and great pics.
Yeah just get the underside nice and clean with any degreaser/cleaner of your choice (as long as it's not citrus oil based) and get a good several coats on there and you'll have that floorpan sandwiched!
Have a question about Second Skin? E-Mail me!
Thanks, that was the answer I was looking for. How long should I let the underside cure before it is road worthy? Thanks!!!!
Edit: Just so you know I am not on any kind of time constraint, I am going to let the inside cure with the doors open for a week before I put the interior/carpet back down, just so you know.
Edited by AMI CUSTOMS
Evo X build log
If you don't mind me askin how much does 1 gallon of that cover? Or even the 5 gallons?
Vehicle: 2008 Mustang V6
Exterior: Blacked Out Taillights, Turn Signals, Side Markers-Black 18x8 Enkei ls5-6000k HID's
Interior: Blue LED Strips with Module for Music-Hardwired Beltronics RX65 with Blue LED and remote button
Sub: 2 10 inch custom subs
Amp: Hifonics BRz 2600
Wire: Knu 0 gauge
Headunit: Kenwood kiv-bt901
Damplifier: Fatmat Rattletrap
Electrical: Stock Alt/Stock Battery/Big 3
Most of the time it only takes a day or two before you can drive it without any worries. I was driving around within 10 hours (sprayed it in the morning, driving it that night) and it's still stuck on there after all these years.
Again, depends on the thickness.
1 gallon will give you about 40 sq. ft. of coverage at 1mm thick. At 2mm thick, 20 sq. ft., and so on.
With 5 gallons you get a hell of a lot covered. At 1mm, thats about 200 sq. ft., 2mm, thats about 100 sq. ft., 3mm, thats almost 70 sq. ft..
ohh wow!!!! thats alot
Wire: Knu 0 gauge
