jl13w7freak Posted May 25, 2011 Report Posted May 25, 2011 I have a SPL Gorilla 5500 Watt Amp. and i think its clipped. Everytime it comes on it will play ok and then when i turn up the volume it sounds distorted. I turned down the gain and everything and sometimes it will still do it. Could it be a power issue because I have 2 batteries in my truck and one of them came out of an 18 wheeler. Im just asking because none of the protection lights are on so i know it isn't short circuited or anything. So what do u guys think. I even thought about connecting a crossover and turning the amp down very low and then set the bass eq on the crossover instead of the amp. Do u think that would help take so pressure off of the amp?
carlosg_313 Posted May 25, 2011 Report Posted May 25, 2011 That's not an amp issue, its your subs and enclosure. Mainly enclosure. If you had your gains all down and your subs still distorts, then its either your subs/box How do the Japanese feel about bass?You know that since 03/11/11 Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.im pretty sure the op wont even notice if it gets even smaller. Refs - Pstone11, porksoda, coleman
EclipseChris Posted May 25, 2011 Report Posted May 25, 2011 That amp doesn't do rated. You could be setting it to rated power, whic would be clipped to all hell. But if it still sounds distorted with the gain all the way down then it sounds like the HU, sub, or box. i resolve to be a nicer moderator. Tercel build R.I.P. Eclipse build Old New V-Dub My feedback.
jl13w7freak Posted May 25, 2011 Author Report Posted May 25, 2011 That's not an amp issue, its your subs and enclosure. Mainly enclosure. If you had your gains all down and your subs still distorts, then its either your subs/box I just used the same JL13W7 ON MY friends amp and it works fine. And the enclosure is the specified one from the jl website. It fine top.
SR20DAZE Posted May 25, 2011 Report Posted May 25, 2011 Headunit bass settings maybe? Hahah damn cody She ain't that sexy. I wouldn't even let her blow me. Those 10 pounds of make up would end up all over my crotch. you dont find dubstep, dubstep finds you hu: Pioneer MVH - P8300BT mids: Alpine sps-600 all four corners highs: Addictive Audio ECST25A,Memphis PR tweeters back sub: 15 inch crossfire bmf box: 4 cubes at 38 hz amp: Rockford Fosgate Power 1000 25 To Life 140.7 on a non sealed trunk car with a five channel so far (old sub audiobahn aw1505q) Build Log http://www.stevemead...ima-56k-beware/ Feedback http://www.stevemead...s-bfd-feedback/
Emmet Posted May 25, 2011 Report Posted May 25, 2011 That's not an amp issue, its your subs and enclosure. Mainly enclosure. If you had your gains all down and your subs still distorts, then its either your subs/box I just used the same JL13W7 ON MY friends amp and it works fine. And the enclosure is the specified one from the jl website. It fine top. Should just post up your box specs up here just to make sure, if theres something wrong with it someone on here can catch it, save you all the headaches of figuring out whats wrong. Maybe try turning all the gains down fully and any bass booster on your HU. Also try a different pair of RCA`s, if their faulty it can cause distortion sometimes. i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah.. You want this to happen to you? Give decent handshakes people. I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
