Audi A4 99 | First build ever, here we go!
Do you have the port opening up through the armrest? thats pretty sweet
Yup :drink40:
Dam that is a slick box. You dont have your RCAs running with your power wires do you?
Thank you! The RCA's, remote and power wire is ran pretty close together under the carpet, should I be worried about this? Never actually thought that it could be bad. :shrug:
Check out my build log!
I dont know how much truth is in it but I have always heard you could get some un-wanted noise coming through your speakers when you have the RCAs near your power wire.
Heres some light reading :drinks:
http://www.caraudio.com/forums/wiring-electrical-installation-help/220897-running-rca-power-cable-amp.html
-Ross
Project Layla
Truck: 99' F-150
Gathering things for my next build.
SoloX18 build:
http://www.stevemead..._1#entry1576460
RE T-line build:
http://www.stevemead...-between-build/
I'll leave it for now. Gonna get meades distortion detecter, unless the shipping breaks my bank lol, and with some experimenting it should come clearer to me.
I learned in school that these cables are twisted to take out "electromagnetic interference" (yeah I had to check it on wikipedia to make sure I wasn't messing up in my head) or some shit like that but I have no idea if the same goes for the RCA's, since theyre twisted too in my case I'm not too worried.
what did you do to make that hole in the armrest? i was looking at mine because im probably gonna do the same on my next build but theres a 1-2 inch layer of foam. How did you seal the foam around the edges?
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
The foam piece behind the armrest is a single piece and is separated from the other foam, so you can just pull it out, no worries ;)
However when i cut the hole i noticed that inside the armrest where the foam ends theres a frame of hard plastic, so if your saw (or whatever youll use to cut it up) gets sorta stuck then you know that you hit the "edge".
The foam piece was about the same size as the armrest.
Want me to try snap some pics on it?
some pictures would be great i dont really understand what you mean by the hard plastic frame
Build Thread
UBL
1948 Plymouth
Sorry for the picture quality ;)
The foam piece is as big as marked on this next pic and should be easy to pull out from even a small hole.
Now here's some pics of the frame itself, it did get some marks when i cut the hole but you cant see it when the cover is on
And here I'm squeezing the frame to try and give you a picture of how it looks. Try it urself i think u can feel it thru the foam.
Hope it helps.
