Bakerman Posted May 28, 2011 Report Posted May 28, 2011 Okay, so heres my problem. The suggested specs for my Fi BTL is 12-14 port area per foot, and a tuning around 32hz. Heres the issue, I can't get one right, w/o messing up the other. So, which is more important to get...the tuning or the port area/foot? I can get close to 32hz w/ port area around 4 or 5"/ft, or I can get almost 12"/ft with a tuning around 37hz. I've tried alot of things from manipulating box sizing, to aeroports and slot ports, different sizes and different number of ports. Can anyone tell me which you would do, or if there is some secret to getting both at the right number that I don't know about? Thanks...
dkahns51 Posted May 28, 2011 Report Posted May 28, 2011 Okay, so heres my problem. The suggested specs for my Fi BTL is 12-14 port area per foot, and a tuning around 32hz. Heres the issue, I can't get one right, w/o messing up the other. So, which is more important to get...the tuning or the port area/foot? I can get close to 32hz w/ port area around 4 or 5"/ft, or I can get almost 12"/ft with a tuning around 37hz. I've tried alot of things from manipulating box sizing, to aeroports and slot ports, different sizes and different number of ports. Can anyone tell me which you would do, or if there is some secret to getting both at the right number that I don't know about? Thanks... defiantly dont do 4 port area per foot.. that would be worthless as all hell. **Clicky>>My 2009 Subaru Impreza Outback Sport Buildlog<<Clicky** I'm messing up 98% of the time
dkahns51 Posted May 28, 2011 Report Posted May 28, 2011 Write out your dimensions/specs/displacement and goals and i will try and crack at it for you.. **Clicky>>My 2009 Subaru Impreza Outback Sport Buildlog<<Clicky** I'm messing up 98% of the time
IH8PunkRok Posted May 28, 2011 Report Posted May 28, 2011 port area is way more important. tuning is personal preference -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
tonedeaf Posted May 28, 2011 Report Posted May 28, 2011 Your common wall setting may be messed up, give us more info so we can plug it in and help with figures. Need box specs your wanting or max specs to design a box. Lengthening the port drops your tuning iirc. Figure out how wide and tall you want your port, then I just adjust length and fiddle with the specs a tad.
Autruche Posted May 28, 2011 Report Posted May 28, 2011 If you use aero ports you don't need as much port area. I've heard 9-11 inches per cube is fine for aeros. Less port area = shorter port. You can hit me up with some specs and I can see if I can whip you up something. Let me know the max dimensions, size of the sub, how much power it will be on, and deisred tuning. Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want
Bakerman Posted May 28, 2011 Author Report Posted May 28, 2011 Lemme see if I can whip something up on paint and torres right quick to give ya'll a quick understanding of what I'm working with here.
Bakerman Posted May 28, 2011 Author Report Posted May 28, 2011 Okay, so here's a Halfway 3D paint view of what I'm working with. Please note that before moving on to the torres, the width must stay at 39" due to the fact I want it to fit all the way across the hatch, and the height can not go over 18.5" tall due to the fact I do not want it sticking up over my rear seats. I want the sub facing front so that I can fold the rear seat down and show it off, and the ports will be facing up. Also please note I'm looking to use aeroports instead of slot ports on this build. And this is the best torres I could come up with. Tuned a little high for my preference, but I would work with it.
Bakerman Posted May 28, 2011 Author Report Posted May 28, 2011 I believe that THIS is the kit I will end up getting. Not bad for $15.xx a piece.
Bakerman Posted May 28, 2011 Author Report Posted May 28, 2011 Or either THIS DIMPLE FLARE KIT which isn't a bad price, and will work better at reducing port noise.
