i have been bumping hard since the day i got my sub (christmas 2011) and for some reason today it started to cut out and stopped working then it would start working again then it would stop so i had to pull my box out and as i was pulling my box out i broke my fucking bass knob... well not the knob but the cord and after i got my sub out i had to cut my 100% silicone just to get my sub out (my sub was siliconed to my box to stop air leaks) but i pulled it out and i thought my wire inside my box came loose or something so i replaced it and made sure it was tight on the terminal and i pealed all of the silicone off my sub and box so i could silicone it down again so i did and i put it back in my truck and went driving for about an hour or so and it started to cut out again
does anyone know whats wrong?
1994 Jeep Cherokee
!@#$%^&*(Soon to come)*&^%$#@!
TONS AND TONS of Audio Technix 80Mil
1 x 270 Amp Mechman Alt
1 x AQ3500D.1
1 x Rockford Fosgate T600-4
8 x Rockford Fosgate T2652-S
2 x XS Power D3100
1 x XS Power D3400
1 x eKs Kable 2 Channel Silver Plated RCA 5M
1 x Knukonceptz Kolossus Fleks Kable 1/0 Red 50FT.
1 x Knukonceptz Kolossus Fleks Kable 1/0 Black 50FT.
4 x Avenue - A605
2 x Fi Q 18
More info, Sub, amp, etc....
¿ǝɯɐƃ ǝɥʇ
i have a Soundstream RBW12 (600watts RMS) and my amp is a Soundstream TRX2.550 (550watts RMS bridged)
1994 Jeep Cherokee
1 x AQ3500D.1
2 x XS Power D3100
1 x XS Power D3400
4 x Avenue - A605
2 x Fi Q 18
my ap1800 was doing the same thing turned out a wire had came loose with in the bass knob and was touching the other causing the amp to go in and out of protect try taking the plug from the knob to the amp completly out and see if the problem persists.
I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
i broke the bass knob wire when i pulled it out of my truck lol and after i broke it i unplugged it so its not that
1994 Jeep Cherokee
1 x AQ3500D.1
2 x XS Power D3100
1 x XS Power D3400
4 x Avenue - A605
2 x Fi Q 18
could be a number of things. Power wire could be wore through and shorts out if you hit a bump. Signal wire could be lose ground could be lose.
2007 caliber
2 Fi ssd 18's
rd audio 3250
xs power d3100 (need 2 more)
stock alt (soon to be singer 350a)
2.75:1 4th order in progress!
i took all of my wires out and checked them over and hooked everything back up tight
1994 Jeep Cherokee
1 x AQ3500D.1
2 x XS Power D3100
1 x XS Power D3400
4 x Avenue - A605
2 x Fi Q 18
I think I know your problem, it's an imaginary sub since Xmas 2011 is still 7 months away :D
In all seriousness though, is the ground tight and touching bare metal (no paint)
Edited by wonderbreadSTS
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
oops i meant 2010 lmao nice catch =D yes it is tight but i could move my ground just in case should i?
1994 Jeep Cherokee
1 x AQ3500D.1
2 x XS Power D3100
1 x XS Power D3400
4 x Avenue - A605
2 x Fi Q 18
  • Who's Online   0 Members, 0 Anonymous, 1462 Guests (See full list)
