korey_hofer Posted June 1, 2011 Report Posted June 1, 2011 your in japan use bamboo, but I say birch previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
audiofanaticz Posted June 1, 2011 Report Posted June 1, 2011 Real birch is damn near 3times the price of MDF. So if its almost the same price as MDF, then it is not real birch. It has a Birch layer on the top and bottom, the inner cores of the wood is normal everyday plywood with knotholes and everything else. Plywood like what is used for your sub-floors in your house, or your exterior walls of the house before the insulation and siding. MDF ruffly $24-30 per sheet Birch Plywood $35-40 per sheet (normally 5-7 layers thick) Birch hardwood grade a/b $69-79 per sheet (normally 11-13 layers thick of all birch) These are rough prices for 3/4inch 4'by8'foot sheets. Also the Birch hardwood comes in 48inches by 96inches While MDF usually is 49inches by 97inches. If your choice is between MDF, and the cheap birch plywood, MDF ALL THE WAY! The 2 thin cores of the cheap birch does not make the wood denser then the MDF, also it is normal low grade plywood for inner cores, so if your rounding over edges and hit a knothole, or there is a knothole on your cut, you will notice a big gapping void that you will have to fill. quality birch...
bre2ts Posted June 1, 2011 Author Report Posted June 1, 2011 The birch being sold here is sold in 4x8 I will ask about the grade Feedback 1 | Feedback 2 you win some, you lose some
korey_hofer Posted June 1, 2011 Report Posted June 1, 2011 Real birch is damn near 3times the price of MDF. So if its almost the same price as MDF, then it is not real birch. It has a Birch layer on the top and bottom, the inner cores of the wood is normal everyday plywood with knotholes and everything else. Plywood like what is used for your sub-floors in your house, or your exterior walls of the house before the insulation and siding. MDF ruffly $24-30 per sheet Birch Plywood $35-40 per sheet (normally 5-7 layers thick) Birch hardwood grade a/b $69-79 per sheet (normally 11-13 layers thick of all birch) These are rough prices for 3/4inch 4'by8'foot sheets. Also the Birch hardwood comes in 48inches by 96inches While MDF usually is 49inches by 97inches. If your choice is between MDF, and the cheap birch plywood, MDF ALL THE WAY! The 2 thin cores of the cheap birch does not make the wood denser then the MDF, also it is normal low grade plywood for inner cores, so if your rounding over edges and hit a knothole, or there is a knothole on your cut, you will notice a big gapping void that you will have to fill. quality birch... he isn't in the US prices will be different. but chances are it's chinese. Even then I would use it over mdf and have previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
bre2ts Posted June 1, 2011 Author Report Posted June 1, 2011 I called the wood shop they said something about it being g2 don't know what that means Feedback 1 | Feedback 2 you win some, you lose some
