have you checked your gains on you amplifiers??
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
what is your ohm load check it with a DMM and also test each coil with like a 9volt battery to see if that coil is working
Edited by 89boxchevy
89 Chevy Caprice (is under construction)
dual alts
4/0 welding cable for wire
red top under hood 3 yellow tops behind the front seat ( who needs a back seat anyways lol)
big 3 of course
Eclipse 3000
interiors are getting rebuilt now
2 crescendo bc2000
2 shocker sig 12s
rebuild pics
I dont have a DMM.
Yes gally i did check the gains they are at 4ish right now.. it sounds like i have a single 10.
Socal, i just started from square one today and did everything all over but better this time. Same problem.
how do you have them wired are they wired together ? and how do you have them wired ? parallel or series or series parallel? oh and are they dual 2 ohm or dual 4 ohm
dual alts
big 3 of course
Eclipse 3000
2 crescendo bc2000
2 shocker sig 12s
rebuild pics
They are wired in some way.. i dunno i looked at a picture from sonic electronix. Dual 2 ohm. Final load should be 2ohm nothing changed on the wireing of the sub from 3 days ago when it worked perfectly fine. The only things that changed were....
Bought used 0 gauge from someone on this forum, to make longer runs.
changed my battery grounds to 0 gauge
and i carpeted the box.
hmm.....this is still a mysterious case..to ask or not to ask...what is wrong? what is right?
nobody knows...il start from the begining..
Master Yoda says...may teh force be with you!and dont lose your mind
your gonna need a mulitmeter to check your ohm load. its the first tool you should buy before even installing a system..
did you do the positive input on a switch to the remote turn on? does it still pop? if so you might have an issue with the amp.
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
buy a dmm it will save so much time in a headache situation like this man and theyre cheap
Grand Cherokee
Team Backwoods Bumpers
DC 15" Level 3's /w 4 Coils
Pioneer deh4200ub
Pioneer 3-ways
Pioneer Tweeters
Pioneer GM-D9500F
Audiopipe 1500.1D @ 14.4v
Clarion Equalizer
Knuconeptz Kollosus 0ga
Knuconpetz Kollosus 4ga
Coming Soon: 270xp / xs1200
looks liek the amp is putting dc voltage by they way they are acting. stop playing them and get a multimeter.
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
blazer
stroker 15
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
DC voltage? whats that?
Where do i get a Multimeter and what accessories do i need to get for it to use it to check ohm load?
  • Who's Online   0 Members, 0 Anonymous, 681 Guests (See full list)
