6berry Posted August 28, 2011 Author Report Posted August 28, 2011 Looks awesome man, I was thinking of doing a 4th order in my trunk. It's going to be glued and assembled inside the trunk right? you should do it! 4th orders are awesome. yeah its gonna be assembled in the trunk, i just mocked it up outside to see what it looked like and to make sure everything lined up good 1999 Audi A4 1.8T::: 4 - DC Level 3 10's in a 4th order Rockford P6002 on Subs for now (3-3.5k coming eventually) MB Quart ONX4.60 for Mids and Highs Boston S50 Components in Front Boston S65 Coaxials in Rear 40 Sq Ft of Second Skin Damplifier Build Thread UBL 1948 Plymouth
6berry Posted August 28, 2011 Author Report Posted August 28, 2011 heres the battery with all wires connected to it. its kinda messy but ill clean it up once i get an xs. and the second fuse holder and here you can see i took out the factory center console because i always left it tilted up and people though it would be smart to open it and mocking up the back wall of the box and then once i cut down the buss bars. im hoping to be able to fit a sundown, dc, or crescendo 3k-3.5k amp at the bottom. 1999 Audi A4 1.8T::: 4 - DC Level 3 10's in a 4th order Rockford P6002 on Subs for now (3-3.5k coming eventually) MB Quart ONX4.60 for Mids and Highs Boston S50 Components in Front Boston S65 Coaxials in Rear 40 Sq Ft of Second Skin Damplifier Build Thread UBL 1948 Plymouth
Ray Posted August 28, 2011 Report Posted August 28, 2011 lookin good.. 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
VIPmeetSPL Posted August 28, 2011 Report Posted August 28, 2011 heres the battery with all wires connected to it. its kinda messy but ill clean it up once i get an xs. and the second fuse holder and here you can see i took out the factory center console because i always left it tilted up and people though it would be smart to open it and mocking up the back wall of the box and then once i cut down the buss bars. im hoping to be able to fit a sundown, dc, or crescendo 3k-3.5k amp at the bottom. question on the bussbars. doesnt wood conduct energy? or what did you do to seperate the positive and negave as for them to not touch and complete the loop?
6berry Posted August 28, 2011 Author Report Posted August 28, 2011 lookin good.. thanks question on the bussbars. doesnt wood conduct energy? or what did you do to seperate the positive and negave as for them to not touch and complete the loop? wood isnt a conductor and the paint on it will prevent the minuscule amount of conductivity present(if any) 1999 Audi A4 1.8T::: 4 - DC Level 3 10's in a 4th order Rockford P6002 on Subs for now (3-3.5k coming eventually) MB Quart ONX4.60 for Mids and Highs Boston S50 Components in Front Boston S65 Coaxials in Rear 40 Sq Ft of Second Skin Damplifier Build Thread UBL 1948 Plymouth
VIPmeetSPL Posted August 28, 2011 Report Posted August 28, 2011 lookin good.. thanks question on the bussbars. doesnt wood conduct energy? or what did you do to seperate the positive and negave as for them to not touch and complete the loop? wood isnt a conductor and the paint on it will prevent the minuscule amount of conductivity present(if any) oh ok... hey listen i have an idea for the ANL fuses under the hood to the battery. you think its possible to put one for bass and one for highs both running a seperate wire back but then the other side of the ANL (closer to battery) have them both linked on a bussbar so you only need one 0 gauge heading directly into your batt. think it would work?
Ray Posted August 28, 2011 Report Posted August 28, 2011 Yes. Thats fine 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
VIPmeetSPL Posted August 28, 2011 Report Posted August 28, 2011 Yes. Thats fine that answer for me? lol
6berry Posted August 30, 2011 Author Report Posted August 30, 2011 fiberglassing is fun until your glove rips. put a layer of 1 1/2 oz chop mat on the bottom and outsides, resined the top piece, and reresined the port. 1999 Audi A4 1.8T::: 4 - DC Level 3 10's in a 4th order Rockford P6002 on Subs for now (3-3.5k coming eventually) MB Quart ONX4.60 for Mids and Highs Boston S50 Components in Front Boston S65 Coaxials in Rear 40 Sq Ft of Second Skin Damplifier Build Thread UBL 1948 Plymouth
6berry Posted August 30, 2011 Author Report Posted August 30, 2011 waiting for the pieces to dry under a light. i dont think i put in enough hardener so its dry but not hard enough to sand without clogging the sandpaper. and i didnt use enough resin on the piece on the upper left and the big piece on the right but it doesnt really matter. i did the piece in the center better and luckily i did it better since its on the back and will be visible. 1999 Audi A4 1.8T::: 4 - DC Level 3 10's in a 4th order Rockford P6002 on Subs for now (3-3.5k coming eventually) MB Quart ONX4.60 for Mids and Highs Boston S50 Components in Front Boston S65 Coaxials in Rear 40 Sq Ft of Second Skin Damplifier Build Thread UBL 1948 Plymouth
