1999 Audi A4th order Trunk Build Video Pg 7
PICTURES PICTURES PICTURES!
it stopped raining so i was able to go out there and get some work done today. i made a circle jig for my routerand got the holes cut in the baffles.
first hole
first baffle done
both baffles in for mockup
hole cut for removable port
removable port piece
port
also i started to make an mdf ring for the rear fill 6.5's but i couldnt figure out how to get the inside diameter small enough since the ring on router is in the way
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
Buy a Jasper circle jig! Absolutely a necessity and you will never look back.
i will definitely buy one eventually but i can not afford one right now. i might have over $600 worth of tickets to pay at the moment :pardon:
Build Thread
UBL
1948 Plymouth
thanks a lot man! i appreciate it :drinks:
Build Thread
UBL
1948 Plymouth
okay last night i realized i messed up my measurements a little bit in torres so i need to change the ratios a little bit. i have 6.29 cubes internal to work with after displacements. does anyone have any suggestions as to what a good ratio would be in this volume?
id stick with 2.2 sealed (1.1 per side). ratio would come out to be ~1.8:1.
m_8e0e9deb0e2a020a7ff1bf0d3a6c3306.jpgth_140x100square.jpgth_140x100rev2animated.gifsoundigital.pngth_Banner_140x100.jpgn221468318568_2854.jpg
yeah thats what i was thinking too.
trimmed the edges off the port
then routered the edges and filled the corners with homemade wood filler
also when the box was mocked up in my car i noticed i will still be able to get my tool box and the widow maker jack out. also i will try to fit a small battery in there under the toolbox like an xs power d375 or shuriken bt20
Build Thread
UBL
1948 Plymouth
Little bit more stuff done. Got the removable port finished.
I really cant think of much else that i can do until i get my ez lok's and my subs in. i need to go buy some fiberglass, bolts for my subs and port, great stuff, and i dont know what else. this build is getting closer to the easy part!
Build Thread
UBL
1948 Plymouth
