DC Sound Lab
As stated above expect it to put out what an AQ 1200d does which is 1200watts RMS @ 1 OHM, thats what it will most likely be rated at since its called a 1.2k could you see more then 1200 im sure you could.
i think dwright was tryin to say its better than aq without sayin it haha
Threw a little edit in there :drink40:
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Lots of Second Skin Damplifier
Under Construction for 2017
You will get 1200w at a reactive 1 ohm load and 12v. Are you going to see this power, probably not unless you have found a way to defeat box rise without wiring ridiculously low to start with, if you have found this please pass on the information.
Just because you buy a 1.2k, 2k, 3k, 5k and so on amplifier, doesnt mean you are going to get that actual power from the amp. The best example I have personally dealt with is 4 Powerbass 3000s(12000w@ 1 ohm) I was clamping 1500w of clean power per amp because I had box rise to about 3 ohms.
If you are building a daily beater, rise isnt something you really need to worry about, only if you are planning to compete and need to squeeze every watt possible out of your amps.
If you choose to go with the 1.2k it will be worth the wait.
Month or so.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
will they take 1/0 or 4 gauge wire?
i would assume 1/0
but only cause dc has the go big or go home attitude
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
I want to use this in an install i have coming up and want to see what size wire to buy for it.
'00 Honda Civic Si IASCA stock trunk/pickup 1 World Record 4/20 150.6/150.7dB
Team DC Team XS Power
Team ISB
Steve's Body Shop
http://www.dcsoundlab.com/
  • Who's Online   0 Members, 0 Anonymous, 991 Guests (See full list)
