Anyone know where to find universal wire harnesses at? I need at least an 8pin harness...one that includes the female and male harness, that I can just slide my own wire into. I plan on making my mids/highs amp removable so that I won't have them when going for spl soundoffs, and instead of having to take out the hex heads and undo every wire, I wanted a plug to run my speaker wire and remote wire through.
you can go to radio shack and get a make your own harness. They are in the drawers with the relay, diodes, leds, etc. pretty cheap too.
formerly known as Blue86f150
this sux camel dicks
Just put a switch on the remote wire?
Because that would be to effin simple. Trust me, I know what I'm doing. The setup I am going with, the amp rack is above the box. If I wanna go to SPL for the day, I need the amp rack out of the way for air movement...so I just use pin connectors for easy disconection, and removal of the amp rack. Frees up cabin space.
Thanks bro...this is exactly what I was looking for!
