i seen peeps line the out side of their boxes in 2x4's to help with box flex. if it works does the whole box need to be covered or just a few key spots?
Edited by kandiman71874
Its spelled ENCLOSURE!!!!!!!!
Team DBs (Driven By sound)
I used it on the outside of my wall. seems to help a good deal. its strong and doesnt add as much weight doubling up on mdf. you can add as much as you want to it will all help imo
2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
do you have to cover the whole thing? no but 2x4s are cheap so why not.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
People mostly do that for their walls. It's like an external frame to the enclosure. If you can build the frame so that it has support in the middle of each large piece it can help drastically. If it is for a smaller, drop-in style box you'd probably be better off with internal bracing using dowel rods or 1/2-13 threaded rod.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
^ this... they are under 3 bucks per... i used around 5 pieces to brace outside of my entire wall
my entire wall will be used for this all except the baffle. it will be 4 layers thick.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
reason i asked is my tfs's are broke in an the box is flexen pretty good on the low notes and dont have the time to tear the box down brace it and rebuild it, but if i can slap sum 2x4's to help stiffen then
im gonna do it
Ive used it several times to reenforce the larger panels. Screw and glue the crap out of it. If your box it big go ahead and to top back and sides, if its smaller listen to it loud and feel the panels to see where it would do the best.
Good luck
Does this smell funny to you? Its your sister :roflmao:
its 7.5 cubes inside after displacement so its a good size box. so i could cover the sides front and back, not sure how the top will be unless i can brace it a lil from the inside
here is how i braced inside of my box might be helpfull.
