Well i installed my CDA-117 last weekend an was working fine. This week it just won't turn on. I check the power going to it I am getting 12v to it I am not sure what could be wrong. Any ideas?
you win some, you lose some
your ascessory working properly? is it grounded ? try hooking it direct to your battery to test if the units bad
i checked the power using the ground going to it.. i have never checked it through the battery how do i do that?
Edited by bre2ts
Thanks James I figured it out before your post it was quite obvious had a brain fart there. After further trouble shooting I realized my constant (yellow) had no power going through it so I ran some wire straight from the batt to my constant and voila it worked. I could of sworn I checked all the fuses but I went back and rechecked and found the culprit and the problem.
i'm glad you got it straight bro.
2009 bmw 5 series
Head Unit Stock
Amplifier-JL Audio JX 360/4
Processor- Audiocontrol LC6
i figured the 12v on the meter was you measuring the yellow constant.
yea i had a major brain fart this morning trying to figure this out... idk what happened but glad i eventually smartened back up.
i do complex wiring at work almost every day, troubleshooting, tracing and rewiring of aircraft equipment but yet this morning i was an idiot. being on leave is getting to me :trippy:
I was going to suggest checking your fuses, but I figured you were experienced enough to have done that already. Oh well, we all have our brain farts :)
  • Who's Online   0 Members, 0 Anonymous, 1025 Guests (See full list)
