I ran into a problem with my amp. Even though it says in the manual that it will run in 1 ohm, it will not. Can I rewire my subs that are currently running 2 ohm loads to 4 ohms so I can run a 2 ohm load through the amp? I don't want to have to send these subs back. Please help!
2004 Ford Mustang GTPioneer DEH-P7200HD head unitMach 460 Factory System
Cadence FXA1600.2
Cadence S2W10
Cadence 4 AWG wiring
Ported box, 2 cubes, 32 hertz
I really need help on this. I should clarify that I know how to wire the subs to my amp. I mean the individual sub impedance. I've looked everywhere and can't find it. I want to switch each 2 ohm DVC sub to a 4 ohm DVC sub so I can achieve a 2 ohm load on a mono amp. I can't believe no one has done this on the internet!
Cadence FXA1600.2
Cadence S2W10
Your subs are 2 ohm DVC?
Then your choices are:
0.5 ohm (all coils connected parallel).
2 ohm (series coils on each sub, connect subs parallel to amp)
8 ohm (series all connections).
Lots of people have changed 2 ohm DVC subs into 4 ohm DVC subs. It just requires a recone is all.
Hammerdown... 1%
"Rewiring" the subs the way you want to is called reconing.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
Oops, I meant making them 2 ohms instead. I need to get a 2 ohm load. I don't plan on getting a new amp right now. I have a Focal 600w amp for my subs. Just not stable at 1 ohm like I thought. -_- Reconing doesn't sound like it's worth the hassle. I guess I'll ship them back.
Cadence FXA1600.2
Cadence S2W10
You would do well to re-read my previous reply...
Hammerdown... 1%
If you have 2ohm DVC subs your running .5 ohms, not 1 ohm. Hince why your having issues.
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
  • Who's Online   0 Members, 0 Anonymous, 925 Guests (See full list)
