JustinWillmon Posted June 16, 2011 Report Posted June 16, 2011 Im in the process of getting my blowthrough designed up and slowly piecing together my build which will consist of 4 15" dc lvl 4's and a few sundown saz-2500 (will upgrade to bigger amps later). My question though is i measure for the actual cut which will enter the cab. Due to the supports that ran through the truck i am only getting about 13" tall by 43.5" wide. Is this a normal size for the cut itself or what size are yall running? The truck is a 2004 1500. The size of the box will be 50"x49.5"x19 so its pretty big. Its my first blowthrough setup so just wanna make sure everything is right before i cut.
6berry Posted June 16, 2011 Report Posted June 16, 2011 If you only want to cut out that area you can do a 4th order and port it into the cab through that hole. that would get you good output and it would look pretty good. also 2 of those sundowns should be good 1999 Audi A4 1.8T::: 4 - DC Level 3 10's in a 4th order Rockford P6002 on Subs for now (3-3.5k coming eventually) MB Quart ONX4.60 for Mids and Highs Boston S50 Components in Front Boston S65 Coaxials in Rear 40 Sq Ft of Second Skin Damplifier Build Thread UBL 1948 Plymouth
JustinWillmon Posted June 16, 2011 Author Report Posted June 16, 2011 Ya Ram_Designs is making the design i think hes planning on a 4th order. I just wasnt sure if that size of a cutout would be to small and hurt the sound.
Namosh Posted June 16, 2011 Report Posted June 16, 2011 I was only able to make my cut 10" tall because of the way the bed angles away from the cab at the top. If I would have went any higher the boot seal would not have worked. Mine is an 05 so I would think the bed is the same as yours. My Ram Quad Cab Blow-through
JustinWillmon Posted June 16, 2011 Author Report Posted June 16, 2011 Good thing I asked I didn't even think about that. How wide did you end up cutting yours?
Namosh Posted June 16, 2011 Report Posted June 16, 2011 About 33" but I should have gone wider. My Ram Quad Cab Blow-through
sewerman Posted June 16, 2011 Report Posted June 16, 2011 Ya, ram designs designed me one for a mega cab. 4th order with port as blow thru.
JustinWillmon Posted June 16, 2011 Author Report Posted June 16, 2011 Ya I'm excited to get started on it. I was just gonna make a cut on each side of those vents on the back wall and I guess go about 10" tall
