safe? to install a home amp to car?
No, wont work properly.
Using an inverter to power that amp will induce a 60hz noise into your setup that you cant get rid of.
they make car amps for a reason, you can find a reasonably priced one at a small size that will perform much better on 12v DC
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
Hes right. I used to do 12v/120v systems in RVs, and going from a 120v source to a 12v amp, just aint working the way you would want it. I used to keep two systems in the RVs, the separate 120v and a 12v running off the battery banks
BUT, PE does have some little cheap multi use hobby amps that will work. You just need to case them up
http://www.parts-express.com/wizards/searchResults.cfm?srchExt=Mfg&srchMfg=133&utm_source=Parts-Express&utm_medium=Flash+Panel&utm_content=sure_electronics+07-29-2010&utm_campaign=Home+Page+Flash+Panel
  • Who's Online   0 Members, 0 Anonymous, 2142 Guests (See full list)
