2000 Dodge DCota (Work in Progress) :D
Eh, I'm getting packages from ups to keep me occupied in the mean time. Still gotta do the baffles, and trim panel. Got my sample pack from Second skin today, shipped Saturday. I gotta remember to thank Jon later.
:rofl:
:wub: N8.
No homo...unless you want there to be. :orly3::ehh:
We both are man, even if the enclosure doesn't show it, we've put a ton of time into all this, and money as well (well it's alot of money for a 17yo lol). Hell, it took around 6months of saving to be able to afford the subwoofers :drinks:
And thanks for that explanation Ricky, the most obvious answer is normally right lol! :)
The amount of water used shouldn't hurt lol. I just use a cup and keep dipping the sand paper in it. Like some one said before it would be better if you had a Orbital sander. I use a Dual action air-powered sander most of the time. I use 80, 180, 320 and then primer. After primer is fully dryed I used 320 on any runs and then 400, 800, 1000. When sanding make sure you leave it a little above where you want when finished because when your switching to smoother grits your goal is to get the sanding scratchs from the harsher grits out. If you have any questions just ask. I may not be a pro but I took 2 years of autobody classes in highschool and going to college for it this year.
Edit: When hang sanding, try not to use the tips of your fingers but the flatest part of your hand or you will put ridges from your fingers pushing more. Always sand in Diagonal motions, Not in straight lines.
-Ross
Project Layla
Truck: 99' F-150
Gathering things for my next build.
SoloX18 build:
http://www.stevemead..._1#entry1576460
RE T-line build:
http://www.stevemead...-between-build/
Great info, thanks man. Never sanded anything before, so every bit of advice helps.
I'll probably pm you when it comes time to prep and paint the baffle :)
Brother came up with this as a basic look to the baffle. Just a general idea of how we want to do it. No photoshop ftl! So tell me what yall think guys. Also, sizes are not to scale, so yeah....
looks pretty good. cant wait to see it complete or to possibly get a demo
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
If you are ever around here, you can get a demo when it's done mate ;)
You should go to the show in Gonzales on the 30th man, from what I've gathered a few SMD members will be going :)
