You have 2 4 ohm coils, which wires you down to two final impedance. Running one amp per coil will only ask the amp for 4 ohms per coil from each amp. Sooooo that will still only be 750 watts per coil RMS.
No no no. Lol I got 2 ohms. Its wired to 4ohm right now.. So when I give one amp to each coil they will be runnin at 1500. ITs running at 750 right now cause I can't wire dual 2ohms to 2ohm. lol Idk if any of that made sense.
-Ross
Project Layla
Truck: 99' F-150
Gathering things for my next build.
SoloX18 build:
http://www.stevemead..._1#entry1576460
RE T-line build:
http://www.stevemead...-between-build/
Lmao. Okay 04S18X2... Its a dual 2ohm sub man..
Yup....sorr I was just way confused. the two at the end of the model number is I'm sure what tells the difference. So each amp running 1500 to each coil would be pretty awesome. According to amp wire calculator on fosgates site, running an 80 percent efficient amp at that power should pull about 67 amps for each amplifier. That's 134 amps at full tilt.
Pluse my doorspeaker amp.. lol Sooo.. I need more electrical. lol I may go ahead and buy it.. Would be cheaper than buyin a recone I was thinking of getting.. Plus It would get louder.. witch puts me further behind on my doorspeakerss.. lol
-Ross
Project Layla
Truck: 99' F-150
SoloX18 build:
RE T-line build:
It pulls roughly 36 amps at full draw. So added up that's 180 amps pull at full tilt. Half that though on music since it's not a constant signal.
Whats the model number of your sub, I'm gonna get to the bottom of this
I got to the bottom of that 2 pages ago ;).
He will be pulling over half of those amps at full tilt on music, especially on Decaf or BigPimpins stuff. I figure he will be pulling 140+ amps, and on the stock alt, no big 3, and 1 battery that's a no no. Stock alts on those trucks are like 130 amp IIRC, so he would be drawing more than his alternator can charge, draining the battery in a hurry.
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
Alright man. I decided against the amp last night.. Found a new recone(4ohm) for 100. Witch will let me run on 2ohms till I got another amp. I'll always have the 2ohm cone when I get a new amp. So I'm gonna get it soon.
-Ross
Project Layla
Truck: 99' F-150
SoloX18 build:
RE T-line build:
  • Who's Online   0 Members, 0 Anonymous, 608 Guests (See full list)
