I just bought two 15" L7 from a friend for $300. I'm wondering which amp will be good enough for these for under $500. They are dual 2 ohm. So a 2000 watt 2 ohm stable amp. I currently have 2 15" cvx's dual 4 ohm run off an aq2200d for my system now but want to add the L7's properly powered as well
Sell the Aq2200d, buy two 1200ds, strap them at 2ohm.
Posted (edited)
It's not good to mix subwoofers :P
Fine, keep the Aq2200, buy two Aq1200s anyway...
Do you have the electrical system to support 4000w? Do you have the proper space to fit 4 15s?
EDIT: I'd pick that Alpine up in a heartbeat.
Edited by Supercharged DCs
Posted (edited)
I have 2004 tahoe. 250 amp alternator running my audio with 2 kinetik hc3800's and my stock alternator running my stock electrical, big 3 upgrade.
Edited by mnrookie
Alright, sounds like your good to go on space & the electrical system. I'd definitely pick up that Alpine MRP-2000 if it's in good condition.
You said earlier that its not good to mix subs, are they going to work against each other or does mixing make sound quality horrible
they wont work against eachother, it just might make the sound quality a little worse due to the different frequencies
My youtube channel, please subscribe
http://www.youtube.com/ballinblaza
  • Who's Online   1 Member, 0 Anonymous, 738 Guests (See full list)
