Arsaces Posted June 23, 2011 Report Share Posted June 23, 2011 Well, as promised, I finished my box, here are the pictures: It sounds nice in my little celica Things to do: Try to clean up the port a bit Get better amp, the xplod is getting extremely hot Weld in supports to the seat to mount the box to, to help prevent theft, and movement Thank you guys for all of the help you have given me, I really appreciate it, wouldn't have gotten this far without you Quote Link to comment Share on other sites More sharing options...
Supercharged DCs Posted June 23, 2011 Report Share Posted June 23, 2011 Holy small port batman! Quote Bassless once again. Can't seem to keep a system for more than a few weeks Saving for a '06 Nissan 350z, look for build around June 2012. Link to comment Share on other sites More sharing options...
RooTxBeeR Posted June 23, 2011 Report Share Posted June 23, 2011 What is that thing tuned to? Also a suggestion I can add is when you clean up the port, sand the corners down like you took a router bit to it. Quote On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5 Link to comment Share on other sites More sharing options...
KillaCam Posted June 23, 2011 Report Share Posted June 23, 2011 What is that thing tuned to? x2 Quote And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log Link to comment Share on other sites More sharing options...
Kevin Posted June 23, 2011 Report Share Posted June 23, 2011 Holy small port batman! Quote Link to comment Share on other sites More sharing options...
Arsaces Posted June 23, 2011 Author Report Share Posted June 23, 2011 What is that thing tuned to? Also a suggestion I can add is when you clean up the port, sand the corners down like you took a router bit to it. Tuned to 40.5hz, my first box I decided to go with the manufacturer recommended tuning. As for the port, you mean basically flare it out? Quote Link to comment Share on other sites More sharing options...
Arsaces Posted June 23, 2011 Author Report Share Posted June 23, 2011 Holy small port batman! Does having a small port affect anything? As long as I use the port calculator and make the length correctly? Quote Link to comment Share on other sites More sharing options...
Kevin Posted June 23, 2011 Report Share Posted June 23, 2011 What is that thing tuned to? Also a suggestion I can add is when you clean up the port, sand the corners down like you took a router bit to it. Tuned to 40.5hz, my first box I decided to go with the manufacturer recommended tuning. As for the port, you mean basically flare it out? Make the edges smoother by sanding them down. Quote Link to comment Share on other sites More sharing options...
Arsaces Posted June 23, 2011 Author Report Share Posted June 23, 2011 Make the edges smoother by sanding them down. Will do, thank you for the input Quote Link to comment Share on other sites More sharing options...
KillaCam Posted June 23, 2011 Report Share Posted June 23, 2011 (edited) Does having a small port affect anything? As long as I use the port calculator and make the length correctly? The length isn't everything you need the right amount of port area for proper tuning. Edit: Area = LxWxH Edited June 23, 2011 by DjCrush Quote And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log Link to comment Share on other sites More sharing options...
