Copper clad aluminum gets hot, vs pure copper.......physically hotter, by probably double.
Clovis Custom Audio 559-392-3600
96 Silverado Single Cab
2-DD9515's Cut-through
1-DDSE Amp
Stock electrical and a couple small stingers, LOL
Get the ofc fleks. How many amps is your alt?
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
Ive NEVER fused the run from alt to batt.. and ive never had an issue
X2, cars dont come with a fused alt to batt either
Yea they do? And I solder my connections and the fuse holder is the kind with the bolts you slip the ring terminals over then put a fuse.
--2004 Toyota 4runner
New Build Log
-2002 Acura Tl-S
Old Build Log
Team DC Audio
spl dust is an option you can get on the coils... it's great for extra 1000 watts of power
where can i get this spl dust and how much is it. is it hard to apply? lol
it does not get twice as hot but it can get hotter. but that doesnt matter. something has to be wrong to make this wire melt. if aluminum just melted and that was normal, NO ONE would use it. and i have a bunch of CCA in my car powering a 12k. the wire is not the problem. its a connection or its shorting out against something.
That and ive used the same kca on my acura last time with no issues for 2 years both vehicles have stock alts the runner I believe uses a 140 amp alt stock.
New Build Log
-2002 Acura Tl-S
Old Build Log
Team DC Audio
I don't use a fuse on mine either, nor does my stock run.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
do you solder with a torch? do you crimp at all first? where on the wire is it melting? you need to answer all the questions, not just one.
and again, pics of the fuse holder, terminals, and engine bay where the wire is ran will help a lot in solving this.
I wont be able tp get pics up till late tonight I'm at work right now but I solder with a torch and the wire isn't melting the fuse block is right where the terminal from the alt wire gets there.
New Build Log
-2002 Acura Tl-S
Old Build Log
Team DC Audio
I dont have mine fused and the only reason i dont is because the peice of paper only told me to add 0ga wire to my existing wire that was already there. No where on that peice of paper did it mention anything about fusing the Positive wire from alt to the battery positive. It only said to do the big 3 and that was it.
This is one thing that has botherd me for a long time because alot of people say you do and alot say you dont need to. Which is the correct answer?
If you had a alt that puts out over 300 amps if you had to fuse it, wouldnt you technically have 2 runs of 0ga wire with what ever size fusing is needed since a single run of 0ga typically can only take 300amps through it?
Edited by cubs_fan0718
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Lots of Second Skin Damplifier
Under Construction for 2017
When i only had 1 alt - bat run the wire would heat up (425a alt) but after adding another run, no problems
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
  • Who's Online   0 Members, 0 Anonymous, 566 Guests (See full list)
