uhoh_45 Posted June 25, 2011 Report Share Posted June 25, 2011 i'm going to be building a steel framed wall in the lumina sometime in the near future and was wondering how all you who have done so attached the wood to the steel frame?? just normal self tapping screws or what i will be using angle iron for the frame welded to the vehicle and then single layer of wood on inside to help keep weight down and maximize space or would pl400 glued to wood and frame be ok with couple bolts through the wood into the steel?? Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
keepinitloud Posted June 25, 2011 Report Share Posted June 25, 2011 the self tappers would work but also I would worry about them pulling but epoxy with the screws would work what is goin into this beastly wall Quote 06 chrysler 300C Hemi one mmatts dreadnaut 15 powered by a planet audio vx 2200d fosgate p200 running planet audio 8" midbass drivers and super compression tweeters stock battery and a stinger spv44 Irragi 300 amp alternator big 3 1/0 http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1 Link to comment Share on other sites More sharing options...
Louisiana Bass Posted June 25, 2011 Report Share Posted June 25, 2011 I beleive there is a way you can laminate te steel to the wood. Quote N8. No homo...unless you want there to be. Link to comment Share on other sites More sharing options...
uhoh_45 Posted June 25, 2011 Author Report Share Posted June 25, 2011 (edited) the self tappers would work but also I would worry about them pulling but epoxy with the screws would work what is goin into this beastly wall i figured if i could drill holes and then weld some nuts to bottom of angle iron and use bolts to secure it with some sort of epoxy and i'll be using 4 apxx 15s and 2 cresendo 5500ds roughly 12k power on tap for now and then later on i would like 4 55000ds one per sub next to apx 18 that is in the car right now I beleive there is a way you can laminate te steel to the wood. yeah thats what i'm wondering what type of glue/epoxy i would need to use to get it to be secure Edited June 25, 2011 by uhoh_45 Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
keepinitloud Posted June 25, 2011 Report Share Posted June 25, 2011 the nuts welded on would work and the suggestion of somehow laminating the wood to metal has potential seeing all those apxx's is te sex!!! Quote 06 chrysler 300C Hemi one mmatts dreadnaut 15 powered by a planet audio vx 2200d fosgate p200 running planet audio 8" midbass drivers and super compression tweeters stock battery and a stinger spv44 Irragi 300 amp alternator big 3 1/0 http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1 Link to comment Share on other sites More sharing options...
uhoh_45 Posted June 25, 2011 Author Report Share Posted June 25, 2011 (edited) the nuts welded on would work and the suggestion of somehow laminating the wood to metal has potential seeing all those apxx's is te sex!!! yeah im thinking of using some sort of loctite pl adhesive such as pl 375 and yeah i love my apx and apxxs so far i have 2 apx 12s 5 apxx 15s and 1 apx 18 and i love them all all i need now is a pair of 10s and i'll be set haha Edited June 25, 2011 by uhoh_45 Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
keepinitloud Posted June 25, 2011 Report Share Posted June 25, 2011 they are makin an 8 now 1000 watts rms Quote 06 chrysler 300C Hemi one mmatts dreadnaut 15 powered by a planet audio vx 2200d fosgate p200 running planet audio 8" midbass drivers and super compression tweeters stock battery and a stinger spv44 Irragi 300 amp alternator big 3 1/0 http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1 Link to comment Share on other sites More sharing options...
uhoh_45 Posted June 25, 2011 Author Report Share Posted June 25, 2011 (edited) they are makin an 8 now 1000 watts rms weird my magnets are roughly 10" round so i donno how they plan on making an apx/xx 8 unless its new neo they were talking about and if you dont mind can you answer my question in your 300 log Edited June 25, 2011 by uhoh_45 Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
Autruche Posted June 25, 2011 Report Share Posted June 25, 2011 Hmm... If you did 2 layers of wood, you could drill though the steel and wood, then put tee nuts in the wood and bolt the outer wood layer to the steel frame, then do an inner layer to cover up all of the bolt ends that would be sticking into the box. Quote Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want Link to comment Share on other sites More sharing options...
uhoh_45 Posted June 25, 2011 Author Report Share Posted June 25, 2011 Hmm... If you did 2 layers of wood, you could drill though the steel and wood, then put tee nuts in the wood and bolt the outer wood layer to the steel frame, then do an inner layer to cover up all of the bolt ends that would be sticking into the box. i was thinking something similar to that minus the t nuts just normal allthread/ bolts bolt from outside frame into car going into wood with a recessed nut/washer then weld the nut to keep it there for good and then putting second layer ontop of that of .5" to cover up nuts Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
