steel frame wall
Could do it the other way, with the bolt head in the box, and the nuts/lockwashers and whatnot on the outside, sink bolt heads into wood. You could countersink the bolt heads and washers into the wood easier than the nuts and leftover thread.
Need Test Tones/Sine Waves? Click Here!
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Pioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE Audio
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Hit me up on Facebook, if you want
for the side walls i would be doing it like that bolt head inside the box and nut outside where i can get to them from outside
for the top/bottoms i'm thinking having the bolts going from the top and countersinking nuts from bottom side under the wood
i really wont have to use to many bolts to secure the wood
if i were to use only 9 bolts 3 rows of 3 i should be able to keep the wood up to allow glue to dry
R.I.P!
(Nov-29-2009)
92 explorer
current build
Yeah, that's true, I forgot about the top and bottoms. Then again you could weld nuts on the frames top and bottom and still do the bolts from the inside, just have to put the lock washers on the inside of the box too.
My Saab 9000 build
yeah welded nuts to the frame and some bolts going into that would work well too
i dont like lock washers as when you put some heat to them the rubber melts and there ruined
i learned about flexlock nuts which are same as lock nuts but without rubber i believe they have a tapered end which keeps tension on bolt
R.I.P!
(Nov-29-2009)
92 explorer
current build
This is what I mean when I say lock washer:
Edited by Autruche
My Saab 9000 build
oh i thought you said lock nut not lock washer my bad
and if boilermaker you see this i'm hoping you chime in with how you did your wall
R.I.P!
(Nov-29-2009)
92 explorer
current build
At least for the first layer, then use screws and glue for the layers after that.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
I would use carriage bolts and lock washers.
fuck didnt even think of carriage bolts on the side walls would work great but not so much for top and bottom/ back it would be a bitch to do
R.I.P!
(Nov-29-2009)
92 explorer
current build
Use carriage bolts for sides, and hex head nuts on the tops and bottoms. Regardless, steel isn't cheap, might as well get a good bolt setup going ya know?
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
  • Who's Online   1 Member, 0 Anonymous, 1939 Guests (See full list)
