corteznewbie Posted June 26, 2011 Report Posted June 26, 2011 well here shortly my amp will be back from the repair shop. its the older autotek mm 4000.1d its rated at 4000 rms at 2ohm mono or 2000x2 rms at one ohm. so which way would be most efficient on the charging system? i have a 180 amp alt and 2 agm batteries Team DBs (Driven By sound)
homiewes Posted June 26, 2011 Report Posted June 26, 2011 well here shortly my amp will be back from the repair shop. its the older autotek mm 4000.1d its rated at 4000 rms at 2ohm mono or 2000x2 rms at one ohm. so which way would be most efficient on the charging system? i have a 180 amp alt and 2 agm batteries either way it puts out the same amount of power at 2ohms and 1ohm.. a 2ohm load would be more efficient on the amp.. but for your alt it should drain the same amount of amps. My youtube channel, please subscribehttp://www.youtube.com/ballinblaza
E a r t h Posted June 26, 2011 Report Posted June 26, 2011 on multi-channel amps, a 2 ohm mono load is the same as a 1ohm stereo load, hence the same power. one difference however, is in bridged mode, the amp is sending one channel signal to the drivers. in stereo mode, you're using both left and right channel signals,which with some material at any giving time, can be two completely different signals and or amplitudes. an excellent example of that would be bass outlaws "stereo bass" track. one channel plays a certain note, while the other is doing something different.
Autruche Posted June 26, 2011 Report Posted June 26, 2011 on multi-channel amps, a 2 ohm mono load is the same as a 1ohm stereo load, hence the same power. one difference however, is in bridged mode, the amp is sending one channel signal to the drivers. in stereo mode, you're using both left and right channel signals,which with some material at any giving time, can be two completely different signals and or amplitudes. an excellent example of that would be bass outlaws "stereo bass" track. one channel plays a certain note, while the other is doing something different. ^This. When you bride a 2 channel amp (I believe the MM 4000.1 is 2 MM 2000.1s internally strapped, so it works just like a 2 channel) each channel sees half the impedance. So either way you wire it, each channel will see 1 ohm nominal. One thing to keep in mind is that if it is 2 2ks strapped internally you won't get stereo effect, cuz both amps will put out mono signal. Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want
corteznewbie Posted June 26, 2011 Author Report Posted June 26, 2011 so either way i wire it the pull will be the same and still get warm? i have 2 fans to keep it cool but the cooler it runs the better the power Team DBs (Driven By sound)
